Old 04-11-2004, 10:00 AM
brad123 brad123 is offline
Rep: 10 Posts: 7
LAMINATION SCHEDULE - skin coat
After the gelcoat is sprayed - how many skin coats? 1 0R 2? Will print show if just one skin coat on 3/4 oz mat is layed in? Thanks for anything you guy's can tell me. brad
Old 04-11-2004, 01:14 PM
Rep: 1397 Posts: 7,216
Need more specifics:
*gelcoat thickness
*gelcoat formulation
*laminate schedule
*core type
*laminate resin type
*resin to glass ratio
Old 05-13-2004, 09:40 AM
Buckle's Avatar
Buckle Buckle is offline
Composite Engineer
Rep: 10 Posts: 83
What I'd got tought
When I was a wee kid, I was tought always double your first tissue layer up to be extra safe and to avoid print especially if your using a 0/90 or something much heavier afterwards.
The cost of tissue is pence considering the cost of a f*** up.
Its not the most sciencetic of approaches but it works. If not make a small trial laminate first. I would to be safe.
Buckle
Old 05-25-2004, 12:20 AM
Misogynist Misogynist is offline
Rep: 10 Posts: 30
Other than "print through" which is cosmetic... are there any other structural problems when "print through" happens?.... So many of the new offshore boats today have the entire hull painted. One new manufacturer doesn't use gel coat at all... just epoxy ... and then covers the entire boat with "bondo"... sands and paints... Do any of you guys with more experience know of any problems building a boat this way?.. any imput would be appreciated. Thanks.
Old 05-26-2004, 03:44 PM
Buckle's Avatar
Composite Engineer
Rep: 10 Posts: 83
One reason why larger boats are manufactured without gelcoat is because of the manufacturing limitation - i.e. especially when laminated by hand, there is are restrictions what laminators can lay up etc.
Secondarly, it depends on the quality of the mould. Why invest labour in a mould for a one off - its more economical to spray the hull.
As to your question, I believe there are not structural problems induced into the moulding, when print-through occurs. Just the fact it looks naff.
Hope this helps
Buckle
(Composite Engineer)
Old 05-26-2004, 05:55 PM
RealityBoatCo's Avatar
RealityBoatCo RealityBoatCo is offline
Rep: 10 Posts: 93
Here's what I use:
3/4 oz mat then 1 and 1/2 oz mat and cloth, then 1 and 1/2 oz mat, coremat, 1 and 1/2 oz mat and cloth. then 1 and 1/2 oz mat, balsa and 1 and 1/2 oz mat and then either woven roving or 1708 bi axial fabric.
Old 05-27-2004, 12:34 AM
Rep: 10 Posts: 30
Hope this helps
So... are you saying that for "one ofs" ,that the laminations can be layed over a plug....with smooth mat on top, and then gelcoated over the top... then the plug removed from underneath?
Old 06-01-2004, 01:04 AM
Boris Vukusic Boris Vukusic is offline
Rep: 10 Posts: 7
after spraying gelcoat I laminate 100g/m2 mat, 2 time 450g/m2 mat or 1time mat 450g/m2 than coremat 2 or 3 o 5mm depends of how tick laminated hull must be (how long boat is),after coremat 1 mat 450g/m2 than rowing .......etc
but it is very important DO NOT PUT MORE THAN ONE LAMINATE PER DAY! ALSO GELCOAT MUST BE SPRAYED 2 TIMES 0,3MM (2 HOURS BETWEEN) DO NOT HURRY, THAN YOU WILL NOT HAVE PRINT PROBLEMS
milky patches in clear gel coat still afloat Fiberglass and Composite Boat Building 3 07-22-2005 04:29 PM
use of kevlar vs e-glass as outer skin tedmelrose Fiberglass and Composite Boat Building 10 05-04-2005 11:35 PM
how much resin? Lew Morris Materials 3 06-22-2004 07:13 AM
Gell Coat Lori Fiberglass and Composite Boat Building 1 06-08-2004 05:17 PM
gelcoat/skin coat lamination issues goodwrch Fiberglass and Composite Boat Building 11 03-07-2004 12:18 AM
