Old 08-08-2010, 05:13 PM
brokensheer brokensheer is offline
Rep: 14 Posts: 108
lamination schedule help
I am thinking about buying an existing mold I have no history on the construction or laminate schedule. Would anyone here be willing to work with me in help to develop one. I plan on building it as a solid glass(ex transom) hull as its a 17' boat outboard power and it will have a cored transom
I have other measurements, Thanks!
Old 08-09-2010, 01:42 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Making a boat is not a problems but will need more info and some pictures of a boat along with some measurments , also what size motor is intended to power the boat ? Need pictures !!
Old 08-09-2010, 02:46 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
brokensheer,
One easy and efficient way to do the extension is simply get sheets of Lamipanel (Corian or Laminex maybe to you) and screw them onto the current hull. They need bracing to follow the exact line of th ehull, but they do so remarkably easy. Do a nice job of the V bottom joint, seal with kids plasitcene (putty) and them gelcoat the insides, followed by the laminate. The old transom is not gelcoated, and the structure is built up direct to it (after stripping off the gelcoat around the edges. You cannot laminate over old gelcoat. The new transom is added of course to the ends of the panels.
No mould is needed then of course.
Old 08-09-2010, 08:13 AM
SamSam SamSam is offline
Rep: 502 Posts: 1,684
Landlubber, wake up! You are dreaming! This is the wrong thread!
Old 08-09-2010, 08:49 AM
Rep: 14 Posts: 108
Chine Beam Transom: 78.5
Chine Beam at Sheerbreak: 77.125
LWL: 170
LOA: 206
Target Displacement: 2200
Wetted Surface Area: 77 sq. ft.
max HP 115
Old 08-09-2010, 09:04 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Are you serious about the displacement???? In ounces, I presume?
You make me curious about the boat. Do you have pictures?
Old 08-09-2010, 09:20 AM
Rep: 14 Posts: 108
no pictures and the displacement is in lbs.
Old 08-09-2010, 05:52 PM
Landlubber's Avatar
Sam Sam......sorry mate......working too hard ....i will take the red pills today to try and wake up to reality.....
Old 08-10-2010, 01:58 PM
old one !
No pictures is not good !! even a few drawings as to the shape etc
So it will be all guess work ! Have you had a schedual of the glass for a equivlent type of boat ? With a 115 motor what kind of speed do you sort of expect to do ? Thats also another factor as to what where and what type of glass you could or should use !!.
Not trying to Fob you off just need more info to get a better idea as every one else will be wondering as well .
Old 08-10-2010, 05:04 PM
Rep: 14 Posts: 108
Thanks all I got it covered!
Composite Bulkhead - Lamination Schedule Sea Jay Fiberglass and Composite Boat Building 7 10-18-2008 07:22 AM
outrigger canoe lamination schedule drewke07 Multihulls 3 10-27-2007 12:21 PM
Understanding lamination schedule wording ? gary1 Fiberglass and Composite Boat Building 6 11-11-2006 12:52 AM
lamination schedule sources willfish4fuud Fiberglass and Composite Boat Building 6 09-11-2006 12:08 PM
LAMINATION SCHEDULE - skin coat brad123 Fiberglass and Composite Boat Building 7 06-01-2004 12:04 AM
