Old 11-15-2006, 07:14 AM
capaworks capaworks is offline
Rep: 10 Posts: 6
Laminating / Vacuum Table
In the process of building a laminating table for a boat project I just started. Table size is 5 x 10 covered with 3/4" MDF.
I plan on applying vacuum against the table for infusion and/or vacuum bagging so need a surface that will be robust. I've read that the formica/contact cement solution works in the beginning but the formica will begin to crack after a while and can also bubble. I figure this is a three year table so I'd like to do it right the first time.
I was considering rolling tooling gelcoat over the MDF with duratec to try and minimize sanding afterwards. Has anyone ever done this? I do not need to have a perfect finish since I will be spraying LP over the parts.
If there are any other thoughts on how to surface the table I'm all ears.
One fella suggested glass but that seems a bit risky and expensive.
Thanks,
T
www.firstlightproa.blogspot.com
Old 11-15-2006, 05:06 PM
wet feet wet feet is offline
Rep: 99 Posts: 258
Glass works but is delicate.MDF is very porous and you will need some kind of impermeable surface.You could apply Formica with Cascamite rather than contact glue.Alternatively,you could use a sheet of aluminium,which can be cleaned with Scotchbrite and normally gives a good release.
Old 11-16-2006, 06:20 PM
Rep: 10 Posts: 6
Thanks
Thanks for the idea..
The woodworking guys use durabond 800 which is also a fermeldahyde-urea glue similar to cascamite.
Found a 5x10 sheet of ultra gloss formaica for $100. So we'll go that route.
Tony
Tony
Old 11-17-2006, 03:27 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
You can use particle board with melamine if you replace it regularly, it's cheap stuff.
Laminating BLueOne Materials 4 04-19-2005 08:52 PM
vacuum bagging or vacuum infusion Eisa Hasan Fiberglass and Composite Boat Building 10 03-29-2005 04:25 PM
vacuum infusion laminating HWL Fiberglass and Composite Boat Building 40 03-28-2005 02:38 PM
laminating on new glass BLueOne Fiberglass and Composite Boat Building 6 03-09-2005 03:17 PM
Flat vacuum/infusion table guest Boatbuilding 4 05-05-2004 06:55 AM
