Old 03-13-2011, 06:52 PM
shizlenut shizlenut is offline
Rep: 55 Posts: 16
Laminate joint questions
I am building a cab on my Boston Whaler out of airex c70 1/2 inch foam and using a laminate schedule of knit mat backed +/- 45 degree 17oz fabric and a 1.5oz cover of mat. I am wondering if I will be able to butt join the laminate on the outside of the cab to minimize sanding, and overlap the joints on the interior for added strength. Is it necessary to overlap all joints or with the right planning, butt some joints for looks on the outside and overlap where the aesthetics aren't so important on the inside.
Old 03-14-2011, 08:30 PM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
It depends on how many layers of fabric will be used.
1 layer...butt joint....zero strength....many layers....it gets better.
You can use an over lap by slightly removing foam from the overlap area, recessing the foam will leave room for the glass with no high spot.
Old 03-15-2011, 06:16 PM
Rep: 55 Posts: 16
Hey thanks for the insite, I actually came across the recessing idea on some other posts. What is the best way to recess the foam, sanding, planning, or some other way to cut it out?
U-joint, CV-joint, Thompson coupling brian eiland Propulsion 20 02-13-2012 08:04 PM
Transition joint or full length butt joint unseen wombat Wooden Boat Building and Restoration 12 06-05-2011 12:16 PM
Hull joint extrusion Lew Morris Sailboats 3 09-09-2005 08:45 PM
Joint methods JosephKeel Wooden Boat Building and Restoration 10 08-10-2004 03:13 AM
