| which kind of keel is better ? See the attached pictures ![]()
__________________ Bruce |
| I see a forepeak and an engine room. What are you asking for ?
__________________ Gonzo |
| I prefer the keel with big motors attached. |
| I like them attached to the bottom....... |
__________________ liberty ships were beautiful |
| The OP has labeled the pictures. I think he's talking about stringers and calling them keels??
| OK, but better for what?
| either design can be made stronger than the other. There are different reasons for using one design over another, and it is not strength. Usually it has to do with the designers goal for the hull. Shallow draft, weighted keel, directional stablity, displacement hull vs. planing hull, etc. So the question of "which is better?" can only be answered if we know what is your design objective for the hull. |
| This is a keel and this is one And this is not a keel: ![]() So then, what do you want to know hyboats? |
| The picture with the engines in has stringers laminated "in situ" which is a lot of work. The picture which is repeated above has received reinforcing from a laminated part. Both options I guess are on the other end of the scale, with below picture in between: ![]() As for the why: It all depends on requirements by the builder. If you plan on doing 100 boats, I would never laminate stringers in situ. Way too much work. I would opt for the second picture, or even better, the one I submitted. I feel the one you gave is more engineered for practical interior requirements then for reinforcing. They did fill it with foam, I see, to generate buoyancy. (and probably stiffness...) This is probably one of the boats which will be on this forum in 10 years, in the "water logged foam" section.
| Thanks Herman. |
| What Kind of Boat Is This? | thkimmel | Powerboats | 8 | 01-08-2010 09:24 PM |
| New Kind of thread | Doug Lord | Forum Questions and Suggestions | 11 | 06-18-2008 05:58 PM |
| What kind of boat is this? | SolomonGrundy | Boat Design | 5 | 04-16-2008 06:28 PM |
| What kind of boats are these??? | TerryKing | Boat Design | 12 | 09-20-2007 07:39 AM |
| can someone tell me what kind of boat this is??????? | jlee203 | Boat Design | 2 | 08-14-2004 06:17 PM |
