Old 01-26-2008, 07:36 PM
Roly Roly is offline
Rep: 222 Posts: 471
Kevlar............
I am about to skin the forward slam zone and chainplate area inside of a strip planker. Laminate is 810gm triax e-glass & 300gm kevlar.
Should the kevlar go against the wood or the triaxial e-glass? If the kevlar does then it will save me putting a 160gm cloth over the kevlar last as a buffer.
I have asked this before with no response;Does it matter?
Old 01-27-2008, 03:22 PM
watergypsy watergypsy is offline
Rep: 17 Posts: 2
I don't know if this is of any help but with kevlar you have to keep in mind that 1) it's has a far stronger tensile strength than compression strength so you really only benifit from it's strength when it's the inside most ply. If you hit a rock for example the outer most layers are in compression and the inner most are in tension.
2) it doesn't "wetout" like fiberglass glass (encapsulates is a better description) meaning the resin doesn't go into the fiber but goes around it. so I would not use it as a first laminate next to wood but would use a layer of fiberglass first inorder to make a stronger bond.
Old 01-27-2008, 03:44 PM
Rep: 222 Posts: 471
Thanks WG.I didn't see your reply until I had done the athwartship layer chain plate to chainplate and put it against the wood. I have two to go
so will reverse the order. I guess with peelply it is not necessary to put a buffer 6oz layer over the kevlar?
Old 01-27-2008, 05:59 PM
lesburn1's Avatar
lesburn1 lesburn1 is offline
Rep: 59 Posts: 20
Sanding Kevlar
Just remember that it is very difficult to sand Kevlar.
Just to be safe put a layer of glass on the outside if you expect to fair the external surfaces.
Kevlar hull r.mike Sailboats 3 12-07-2007 04:08 PM
Kevlar Guideboat yellow cab Boatbuilding 7 10-20-2007 09:13 PM
Kevlar/eglass MichaelTK Materials 8 10-13-2006 11:48 AM
kevlar canoe blair50 Boatbuilding 11 05-06-2006 08:06 PM
9 oz kevlar Materials 3 12-12-2002 04:55 PM
