| issues with powder bound mat Hi, We are using a powder bound mat with iso resin as a skin coat. I have noticed that the mat has wetted out ok, but then as it has cured it has gone shaded . I am wondering if this could have been caused by the resin being under temperature (stored in the cold) and thus the powder binder has not been disolved by the resin. Would be interested if anyone has any ideas? Cheers Neville |
| Neville, sounds like an issue I had with some emulsion mat some years ago, then there were multiple options, & switched to powder bound & a different resin brand then all OK! Ondarvr would be the man to come in on this. Was the resin cold or the whole workshop, laid at the start or end of the day, hows the mat stored- any possiblity of being damp etc? Is the shading in the fiber pattern or the resin looks "milky" all over? I think your gunna have to do a series of small test panels, using different catalyst & % levels, different brand mat, different times of day/shop temp etc All the best from Jeff. |
| Also, do you have pictures? at least let the resin heat up to the same temperature as the workshop. A barrel of resin can take as long as a week to heat up. IBCs even longer.
| The "gone shaded" part isn't very descriptive, but if you are seeing individual strands that show up after (or during) the cure process, but were for the most part invisible prior to it, it can be either the resin, mat, catalyst type or %, or shop conditions. A more thorough description of the problem is needed for an accurate answer though, then a couple of tests can be run to verify which may be causing it. |
| powder coating | jim lee | Materials | 18 | 03-02-2010 07:36 PM |
| To mat or not to mat, that is the question | waterbaby | Fiberglass and Composite Boat Building | 7 | 01-27-2008 08:51 PM |
| powder coating masts | luso | Metal Boat Building | 8 | 04-17-2007 09:02 PM |
| Portable powder coating systems | danjaddak | Marketplace | 0 | 01-08-2007 03:34 PM |
| Any luck with powder coating? | Rocinante | Materials | 4 | 11-26-2004 08:41 AM |
