Old 03-23-2009, 01:18 AM
San Juan Sailor San Juan Sailor is offline
Rep: 10 Posts: 6
Internal or external chainplates?
I'm restoring a 32' Mariner ketch. A previous owner had replaced the mizzen chainplates with external ones. I'm not sure of the reason yet. So I'm wondering if anyone has any opinions or preferences about internal or external chainplates. I could go either way at this point.
I have a boat restoration blog going;
http://www.sailblogs.com/member/rebuildingmariner32/
Dan
Old 03-23-2009, 01:30 AM
dreamer's Avatar
dreamer dreamer is offline
Soņadora
Rep: 188 Posts: 305
I think the current issue of Sail magazine has a brief discussion on this. In the article, the old chainplate corroded in half. That would be my guess with your boat. That or they were pretty close to corroding.
If it doesn't matter to you, I would think external chainplates would be the most worry free. At least they'd be easy to inspect. Just make sure you've got the 'knees' for them (backing).
I would guess you don't see external chainplates much just because they are not the preferred 'look'. Technically they'll give you more support than internal chainplates.
Rick Beddoe
s/v Soņadora, 1978 Baba 30
Senior Designer, Sons Creative
"Study nature, love nature, stay close to nature. It will never fail you" - Frank Lloyd Wright
Old 03-24-2009, 04:05 AM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
Old Chinese boats were prone to glass in stainless steel chain plates, a bad idea at anytime.
Stick with the external plates mate, they are honest, and visible. Corrosion from locking out the oxygen is an undesirable consequence of burying ss.
Old 03-24-2009, 08:10 PM
Rep: 2891 Posts: 8,798
From a performance stand point check to see if you inboard chain plate locations, interfere with the boom's travel when the sheets are well eased out. If you need more boom travel, then an outboard mount will offer a little.
Other considerations are leak potential (as previously noted by others) chaffing other boats in a "rafting" situation or at a dock, where the exposed chain plate fasteners can carve right through a boat parked next to you in short order.
Headsail sheeting angles aren't an issue. Mizzen mule sheeting angles shouldn't be an issue either.
External chain plates are easy to inspect and easy to bed. They aren't as "modern" as internal and may not be in keeping with the rest of the style of modern yachts, but yours should have no difficulty with this aspect.
External Tank definition problem in hydromax ilgazcan Software 4 12-06-2008 10:18 AM
external radiator for cooling system mattoc Powerboats 0 07-01-2006 12:32 AM
Need help: adding external flotation pods ghb69 Boatbuilding 2 03-28-2006 11:44 AM
Use of plywood for internal structures RubinB Fiberglass and Composite Boat Building 1 08-19-2005 11:59 AM
Internal keel reinforcement fishboat Sailboats 11 10-10-2004 09:09 AM
