Old 04-15-2009, 01:48 AM
patrick99 patrick99 is offline
interior of coldmolded boat
Newbie here - tried to search the previous posts but its hard to get what I need. And the Gougeon brothers book does not specifically state what I need. So, Here goes.
1) The inside of this coldmolded tri is unfinished, ie. bare wood.
Should this be painted - if so, I could no longer see where bad spots might be starting - or should it be epoxied - expensive to the whole inside - or just epoxy the "bilge" area most likely to get wet.
2) At the hatches the fibreglass is peeled away from the wood. Do I just slop some more epoxy in the gap, or do I cut the glass back and then re-epoxy - if so how far back do you go. (assuming the wood underneath is not wet/damaged).
Any advice or links to advice gratefully received.
Old 04-15-2009, 02:44 AM
Rep: 2891 Posts: 8,792
Find out what the adhesive was for the molding process. Most use epoxy. If this is the case then epoxying the whole of the bare wood surfaces is the way to go for durability and longevity. Epoxying only areas that might get wet doesn't use epoxy to it's full advantage, so you might as well just use paint instead.
Delaminated fabrics need to be ground back until you're at good bond, then patched. Any wet wood needs to be dried out to about 15% moisture content, better if 12% before new laminate is applied. Any rot needs to be removed, new wood or filler used to fill the void(s) then finished as desired.
Boat interior design MicahG Boat Design 3 09-23-2007 07:01 PM
boat interior devanwon Powerboats 4 05-10-2006 09:06 PM
boat interior devanwon Marketplace 1 05-10-2006 07:16 PM
Boat interior Guest Fiberglass and Composite Boat Building 6 09-09-2004 01:49 AM
Tug boat interior CaptJimTpa@aol. Open Discussion: All Things Boats & Boating 3 11-10-2003 09:25 AM
