Old 12-14-2009, 03:17 AM
Rep: 700 Posts: 691
Interior coating
Gday all
I am painting the inside of my foam sandwich cabin top on the cat. I haven't faired it with a longboard and want a finish which will not show up my mistakes. I am thinking about rolling a flat polyurethane with a stippled roller to get a nice orange peel finish which will still clean well. I do not want a water based acrylic finish. The base coat is epoxy high build primer.
cheers
Phil
PS - I know I could fair it more but I won't. I have faired it already but want to stop at the point I am at now.
Old 12-14-2009, 09:05 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
What you describe is exactly the way we did small dinghies on the inside, when I was running an apprenticeship at a local boat builder. Works pretty well.
Roll on the paint, waita minute, then roll with a coarse roller or stipled roller, and you will get a nice texture.
Old 12-14-2009, 09:27 AM
Steve W Steve W is offline
Rep: 360 Posts: 686
Phil, ive used awlgrip with some cabosil mixed in and then rolled on with a texture roller with good success,the only problem is that i did the various parts before they went on the boat,ie,the ply/foam/glass deck panel were painted first and the cabin front at a later date and then installed,then the cabin top at a later date again and they didnt all come out the same texture,nice but not quite the same,mixing in the cabosil the same in each batch can be tricky,one trick ive learned is to run the cabosil thru a blender before mixing it in to the paint as it tends to be a little lumpy straigh from the bag.We often do the same thing for non skid except with a bit more cabosil so it will peak rather than slump.
Steve.
Old 12-14-2009, 10:35 AM
Herman's Avatar
Resininfusion.info
For antiskid that way I use a product from Sicomin (now MAP yachting, at least for the paint division) which makes a rubbery coating which "peaks").
As for mixing in fumed silica (cabosil, aerosil, etc) best is to do this a day before using:
Mix in really well.
Leave to rest for 24 hours
Mix really well again
Filter through a fine sieve
This is what we do when making our own gelcoats (there are more ingredients, do not worry...) and it works well.
And make sure your silica does not eat moisture. This will make it lumpy as well.
Old 12-14-2009, 01:31 PM
Rep: 700 Posts: 691
Thanks for the help guys
With the rolled on paint did you flatten it or just stipple a gloss paint?
cheers
Phil
Old 12-14-2009, 03:01 PM
Herman's Avatar
Resininfusion.info
We just took glossy paint. 2K PU will flatten a bit when torturing it like that when curing. Will give a nice, semi gloss, easy to clean surface.
deck coating skiffish Materials 35 01-24-2009 10:35 PM
coating for steel gotwind? Boat Design 7 03-31-2007 05:13 AM
Coating Fibreglass Poida Wooden Boat Building and Restoration 3 07-27-2006 04:07 AM
Bondo hull coating EASI54 Metal Boat Building 15 09-25-2005 08:32 AM
Coating Steel Bob Smalser Boatbuilding 6 11-29-2003 11:37 PM
