Has anyone retrofitted insulation to a FRP hull?
After living aboard for a cold North Carolina winter, I'd like to insulate my hull before moving the family back aboard.
We have several areas where large portions of the inside of the hull are exposed (painted). The condensation was awful. Most of the paint on inside of the hull which had been perfect for 20+ years failed. The lockers were damp, and the temperature inside ranged from 70 at our heads to 40 at our feet.
My thoughts were to to glue marine vinyl with contact cement to panels of Elastomeric insulation such as this from Grainger. This is the stuff that most pipe insulation is made of. These panels would then be glued to the bare fiberglass inside of the hull. This should give almost R4 which is better than nothing.
In the head (at the bow) I was going to glue strips of foam (corecell or perhaps cheap PU) to the hull and glass over. I've never had a problem with oil canning but some extra stiffness can't hurt.
Should I insulate below the cabin sole? should I insulate the bottom of the cabin sole?
Anyone been here before?
Thanks
Thanks
