Old 02-09-2009, 07:09 PM
Westerly23 Westerly23 is offline
Rep: 10 Posts: 18
I bought a 48" x 300' roll of 3/8 cork off ebay for cheap. I made paper templates of all the lockers and spaces on the baot and cut the cork to fit. Super-77 spary adhisve (3m) worked best for me. Contact cement was a joke, even on a sanded surface.
The cork was glued directly to the hull. It made a huge difference. my clothes are no longer wet. the boat is much warmer too. The ceiling area was insulated with rigid foam board. I just picked up anothe bare hull, I'll be using cork up there this time around.
The cork looks OK, but if you want you can be creative and cover that. In some areas I corked between battens and then ran mahonagny strips lenght wise for that classic interior look.
One cation with foam, many of the foams (rigid) have a skin. they don't flex reall well and the skin could part from the foam letting the while thing buckle a bit.
Ceramic Insulating Paint RCardozo Open Discussion: All Things Boats & Boating 5 04-06-2008 10:04 PM
Bare Fiberglass Hull 22-24 MYWAY Powerboats 1 05-03-2006 07:16 AM
insulating deck cover Specmar.Aus Metal Boat Building 9 02-08-2006 01:39 PM
Heat insulating fabric help Archea47 Materials 7 05-11-2005 02:09 AM
Heat insulating fabric/fiber Archea47 Fiberglass and Composite Boat Building 4 05-06-2005 08:32 PM
