Old 12-10-2007, 06:29 AM
Nojjan Nojjan is offline
All thumbs...
Rep: 23 Posts: 104
Infusion vs old style bagging?
What is the gain in glass content when using infusion compared to old style wet layup and then vacuum bag? Other structural advantages?
/N
Old 12-10-2007, 06:51 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
Based on my limited experience I'd say the difference is negligible. The method chosen would be dependant on the part being produced. Infusing a part results in a little bit less waste (breather material) and much cleaner (less epoxy all over the place).
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 12-10-2007, 05:54 PM
Splint Splint is offline
Rep: 32 Posts: 79
You might find there's less chance of air bubles in the finished part using infusion. It probably comes back to how well the wet layup was set up in the first place. Realisticly there should be insignificant variation in the end result between the two types of layup.
What is vacuum bagging? RTaylor Boatbuilding 6 04-06-2008 01:14 PM
Help vacuuming bagging panels James Mills Fiberglass and Composite Boat Building 6 02-24-2007 11:47 AM
vacuum bagging or vacuum infusion Eisa Hasan Fiberglass and Composite Boat Building 10 03-29-2005 03:25 PM
Infusion vs wet-bagging yokebutt Fiberglass and Composite Boat Building 0 03-25-2005 09:46 PM
vacuum bagging info Psycho D Fiberglass and Composite Boat Building 1 10-04-2003 07:23 PM
