Old 11-10-2010, 08:08 PM
gages gages is offline
Rep: 10 Posts: 14
infusion versus hand layup
I currently hand lay sea kayaks and am investigating if going infusion.Currently the layup is in the deck 2 layers of CSM and one layer of cloth with some bits of core in the flatter sections for rigidity and in the Hull one layer of CSM and one layer of 450 Double Bias and then a layer of cloth.
I join the hull and deck on the same day and currently a layup takes appox 6 1/2 hours from start to finish
My question is
.would I save any manufacturing time by going to infusion ?
.How much stronger would an Infusion layup be than a good quality hand lay?
. Would I still be able to use the above layers as well as 300gms Satin Weave Kevlar?
Just trying to weigh up the pro's and cons ?
Thanks
nadgeekayaks.com.au
Old 11-10-2010, 08:20 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
Are you hand contact or doing some wet bagging now?
Slippery when wet.
www.cheetahcat.com
Old 11-10-2010, 09:22 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
My question is
....I doubt it, cos the time to set up is quite long, the drain tubes etc all need to be set in place...and then vacuum tested...before the resin is allowed in, so no, it would in fact take longer overall. The resin flow when it is turned on is very fast compared to say hand layup, but the set up and removal times will muck it all up.
...it would be stronger as there would be less resin used, the ratios would be much better.
....yes if you wish to, you can do that many layers without any worries in infusion, but remember , it all has to be tested to hold vacuum, not worth the risk of doing it all and hoping the vacuum will hold, it HAS to to get the resin to flow through all the layers.
...stick with what you are doing, it is OK.
Old 11-10-2010, 10:43 PM
Rep: 10 Posts: 14
No it's all hand contact no bagging
nadgeekayaks.com.au
Old 11-11-2010, 02:26 AM
Rep: 1493 Posts: 7,447
You can infuse by vacuum or pressure. Which method where you looking at?
Old 11-11-2010, 02:57 AM
Rep: 10 Posts: 14
Vacuum pressure was what I have been looking at but am wondering if the set up time etc is to any real benefit over my hand layup ,which produces a very high quality job at present but you hear so much about infusion etc
nadgeekayaks.com.au
Old 11-11-2010, 02:59 AM
I think infusion is only economical on complicated and large laminates.
Old 11-11-2010, 01:14 PM
Stumble Stumble is offline
Rep: 604 Posts: 1,086
Gages,
Not being a builder my experience is limited in the process, but I have done some small parts both with infusion, vacume bagging, and hand layup.
In my experience vacume infusion is by far the easiest process for a number of reasons.:
1) All of the layup is done dry. So making sure the orientation is a breaze, and correcting a mistake is effortles.
2) Not working under a time restraint for me relieves the stress of the layup.
3) Once the vacume is applied there is plenty of time to check the bag for leaks.
4) Once the epoxy is pulled there isn't much to do but wait for it to cure.
Of course I am not a manufacturer and don't work in it every day, so your guys may not have the same problems I do. That being said, infusion if done properly leads to a stronger product that is lighter and requires materials to do correctly. So for a manufacturer I would argue that once the process is learned you could make a higher quality product with the same amount of labor (generally), that requires a smaller investment in material cost.
Old 11-11-2010, 01:46 PM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 336
Infusion is more fun.
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Old 11-11-2010, 02:18 PM
Rep: 84 Posts: 661
If you setup with a reusable bag system and try to reduce the setup maybe it can be integrated seamlessly into your operation .
Slippery when wet.
www.cheetahcat.com
Old 11-12-2010, 03:51 AM
susho susho is offline
Composite builder
Rep: 62 Posts: 66
like rtm light but you need to calculate if the cost of the extra mould justifies the investment. it is a nice process though, if you need a lot of products.
Old 12-05-2010, 09:58 PM
variverrunner's Avatar
variverrunner variverrunner is offline
Rep: 60 Posts: 58
Hayes,
another factor is avoiding all of the goo. With infusion there is almost no mess. Laser sail boats are infused using a reuseable Vac bag using a brushable silicone. If you build a more than a few boats a month , getting set up for infusion would be healther for you, use less resin, and give you stronger lighter finished yaks
Hope this helps
Allan
Old 12-05-2010, 10:06 PM
Rep: 60 Posts: 58
Gages
the silicone is mentioned is made by smooth-on. You can see a video of it being used by laser @ smoothon.com. I have not used it yet, but I am about for making infused canoes.
And Jim lees is on the mark. Infusion is infinitely more FUN.
Allan
Old 12-06-2010, 02:05 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Will you save time? There is too little information for that. 6.5 hours is what it takes now. But what is the breakdown of those hours? Do you spend 6 hours of laminating, or 6 hours of glueing the thing together?
The funny thing if that by implementing infusion, usually the whole production setup is reviewed and reorganised. Which makes for some saving in time, even if you do not infuse.
All in all, time savings on smaller objects should not be the goal of switching to resin infusion. Unless you switch to RTM-Light, in which case you end up in a die-hard production facility. (which is not bad either). If you make 1 hull per day, or 2 hulls per day, per mould, and preferably a couple of moulds, that would perhaps be the way to go. (at a weight penalty, compared to infusion under a bag)
Reasons for switching to infusion can be many:
-less resin contact
-less styrene emission (polyester)
-more constant quality
-higher quality
-higher strength (more fiber, less resin)
-the ability to employ less expensive workers
If you choose to convert to infusion, keep in mind that you will have to review your laminates. They will become quite a lot thinner, and you will have to compensate for that if you need the stiffness. You could add more fiber, more voluminous fiber (continuous filament mat) or a core (Lantor Soric LRC in 1,5mm could do the job for you, or a thin foam core, or cork)
Old 12-06-2010, 05:58 AM
Rep: 60 Posts: 58
Gages,
You might enjoy this Link. I came across after googling "Soric" as Herman recommended.
http://www.compositesworld.com/artic...-time-and-cost
Allan
Difference between infusion polyester and regular hand lay-up polyester? erikssonniklas Materials 2 01-14-2008 10:48 AM
Winches. 2nd hand Mychael Open Discussion: All Things Boats & Boating 0 03-19-2007 04:47 PM
Vacume Infusion Layup Question Salmonid Fiberglass and Composite Boat Building 1 10-11-2006 08:54 AM
Second Hand Software guest12020101217 Software 1 09-12-2003 08:34 PM
