| Infusion - resin up and down.. I am trying to infuse four layers of glass and 1" thick foam inbetween. Looking the inlet tube I have seen that some resin is entering into the test piece and then the infusion stops with the resin going "back" leaving a bubble of air in the inlet hose. After 20-30 seconds infusion start again and stops after 10-15 seconds. Wetting were slow, in the finish I have suceeded. Do you have any explanation? What are the levels of vacuum that you are using when infusing? |
__________________ Slippery when wet. www.cheetahcat.com |
| Thank you for your answer. Correct me, but when I try with high vacuum levels, my impression is that there is no "room" for resin to go thru? I have understood that after the surface is completely wetted I should apply full vacuum. Also, I am novice can you pls explain "double tape line". Made 2mm holes in foam every 20mm. |
| There is plenty of room for resin to travel. Even when the fibers are fully compressed (at endless pressure) there is about 30% of volume for resin. For now, try the following: -increase vacuum. As low as you can go. -check, double check and triple check vacuum integrity. Do you have any prior experience with resin infusion? Did you work at Prinz by any chance?
? I have heard that they closed their business here in Croatia. |
| Seriola, Email me and I will send you a 100 page pdf on the subject from one of the main suppliers. There are a few issues here to be attended to.
| My email is serioladumeriliAThotmail.com |
| My file is over 56Mb, can anyone help me to get this through hotmail (max 25Mb)...it is a pdf file. I have tried to zip it, but it comes out the same size....
| Well that was my homework. I can obtain -30mm vacuum, the picture was taken when infusing. I will start next time with full vacuum. |
| You can use www.transferbigfiles.com. Can you include my address? herman at bugattibuilder dot com About Prinz: I hoped you would have worked there, then you would have seen some infusion work. They unfortunately stopped now.
| Hello i'm interrested by you infusion process files Can you send me please michelcouderc64@yahoo.fr http://www.izarra-yachts.com/ Best regards Michel |
| I'd love to read through the 100 page document you have! If I can bug ya to send it over I'd be much appreciative! DallasAB at GMail dot com Thanks bunches Mate! |
| Fellas, yes I do have this file, it is the DIAB booklet in pdf format, but it is 75Mb I have now seen and tried to get it across. I tried for herman yesterday and it ran out of time, so doing it again now. How do you get it from Transfer Big Files herman, do you have to buy it?
| You can upload it to rapidshare.com, and then post the link here for all to download. No need to register etc. |
| Resin infusion and resin content | sorenfdk | Fiberglass and Composite Boat Building | 23 | 05-17-2011 07:02 AM |
| Best Resin for infusion | Amon | Materials | 7 | 08-18-2006 09:56 AM |
| Resin infusion | Danielsan | Fiberglass and Composite Boat Building | 28 | 11-13-2004 04:13 AM |
| resin infusion ??? | mikeskip | Fiberglass and Composite Boat Building | 6 | 08-18-2004 06:16 AM |
