| OK, idkfa, I have posted it on rapidshare, can you tell me how to let you know how to get to it, I cannot see how to do it. Ta, John
| There somewhere must be a link to the file or the download page, you can spread that link around (or post it here).
| Herman, please advise if you know where to find it, I have not been able to do so......
http://rapidshare.com/files/43354448...ion_Manual.pdf |
| Thanks Apex, there are a few people here that would like to get to that file.
| Quote: 404 File not found.. But does not matter, my link (provided by Landlubber) works.............. ![]() |
| a quick suggestion Seriolla, I took a quick look at your photos and have the following suggestion. Move both heli-tube epoxy supply line to lay on top of the edge of the infusion media, equally distant from the part. Your current set-up appears to have the bag hard to your lower mold surface which will cause the epoxy to struggle a bit to get to the part. Allan |
#25
| variverunner, thank you. I have seen on the downloaded pdf from this thread, page 57, same suggestion. My new test piece is ready, I'll try to infuse today. brgds |
#26
| Good luck Seriola, Keep us posted with your results Allan |
#27
| This time the infusion was perfect! It took about 3 minutes (3x400g+25mm+2x400g). I did not used the top inlet. Thank you for help |
| Resin infusion and resin content | sorenfdk | Fiberglass and Composite Boat Building | 23 | 05-17-2011 07:02 AM |
| Best Resin for infusion | Amon | Materials | 7 | 08-18-2006 09:56 AM |
| Resin infusion | Danielsan | Fiberglass and Composite Boat Building | 28 | 11-13-2004 04:13 AM |
| resin infusion ??? | mikeskip | Fiberglass and Composite Boat Building | 6 | 08-18-2004 06:16 AM |
