| infusion just wondering if anyone would have attempted to infuse a hull of a catemeran upside down. The hull was damaged in high winds and delaminated big time in the tunnel and they need it fixed by infusing it from the outside. |
| No problem ,my stuff is upside down on the jigs.
__________________ Slippery when wet. www.cheetahcat.com |
| this cat is all finished inside it has to be fixed from the outside going in without tearing everything out from the inside |
| Turning a finished and used boat upside down can become messy (tanks, engine, etc) but for the infusion there is not a problem at all. You could also use spray glue to hold the fabrics upsidedown against the hull. Once the bag is on, it will not fall down. Multihull laminates are not that thick usually.
| use spray glue to hold the fabrics ...yep, there is a special glue make just for that very thing, have a read of the DIAB website, we used em in China for the very same thing.
Are you sure the foam is still sticking to the inner shell? No, you arenīt. That is your main problem, not the way to apply the new layup. Regards Richard |
| Good repairs need thorough examination. For the spray glue it is not a problem to keep fibers to foam core. I have some reports on the spray glue I sell which claim that ILSS losses are within the normal deviation of the test results. Or in plain words: they were not able to determine a loss. On infusing upside down: I recently supervised some pipe repairs (joint reinforcement), and as you can understand, half of the infusion was up-side-down. No problem at all. A bit fiddly at times, but nothing to worry about.
| Try this: http://www.ok2spray.com/index.php Nice stuff.
| I have used Infuzene for years and on some tough complex jobs.
| Wormholes in infusion? | jim lee | Fiberglass and Composite Boat Building | 5 | 01-13-2009 07:49 PM |
| Vacvuum infusion F U # 2 | Fanie | Boatbuilding | 58 | 12-01-2008 11:08 AM |
| Infusion Help needed ( | jestah | Fiberglass and Composite Boat Building | 5 | 06-05-2007 10:57 AM |
| Resin infusion | Danielsan | Fiberglass and Composite Boat Building | 28 | 11-13-2004 04:13 AM |
| infusion | pdesign | Materials | 1 | 08-18-2004 09:41 AM |
