Old 02-05-2012, 12:14 AM
dshowalt dshowalt is offline
Rep: 10 Posts: 7
Infusing Panels and Ribs at same time?
I am looking for feedback on infusing the Panel and a stiffening rib at the same time. In the attached .pdf the panel is approx 50" by 96" and the stiffener is about 3" wide by 1" high. Should I infuse the panel first and then place a foam core for the Rib and infuse that as a secondary process? Or can I lay the Panel and Cloth and Foam Core for Rib and Cloth over Rib all at once? Will the Resin Reach the area under the Rib Foam and wet out the cloth between the panel surface and the Rib?
Old 02-05-2012, 12:41 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
Originally Posted by dshowalt View Post
... Will the Resin Reach the area under the Rib Foam and wet out the cloth between the panel surface and the Rib?
Its a good idea, but I guess the problems is that you will not know if the wetout was successfully unless you later drill an inspection hole - or two, or three.
The placement of the vacuum lines will be critical, but even then you wont be able to see it working or - not.
Is it worth the time and trouble of a few test runs on small samples, versus doing it in two stages ?
It seems at first glance that the second stage stiffener is such a small component, doing the rib section by hand as stage 2, would probably be the most efficient method overall, unless you have to do many units.
Old 02-05-2012, 07:53 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
You can do this in 1 go. Make sure you have a permeable fiber under the stiffener (unifilo / continuous filament mat) or a rovicore / polymat material.
also a vacuum line on top of the stringer is not a bad idea
Old 02-08-2012, 02:06 AM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 336
We do this all the time. Drystack the part, lay on the rib core and lay glass over it. Bag-Shoot-presto! We find that this keeps the part closer to the original shape. Less warping.
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Old 02-13-2012, 05:41 AM
latman latman is offline
Rep: 14 Posts: 48
I have infused a Soric cored deck and a 50cm long X 3cm wide PVC stiffening foam rib in one shot on a kayak before , is the positioning of your rib critical ? I agree you will need a permeable layer under the rib and if a permeable layer is above the rib it will be wet out at the same time (or release film and a flow media).
infusing a multi part mold Fgayford Fiberglass and Composite Boat Building 4 01-17-2012 08:21 AM
flow net/mesh for infusing Vanbokklen Materials 7 06-13-2011 01:02 PM
Working Time, Pot Life, Open Time, Gel Time... Huh?! CatBuilder Materials 48 08-01-2010 02:38 PM
Finish surface from infusing a multi-sided part around a core Tarek Fiberglass and Composite Boat Building 7 09-25-2009 09:54 AM
Ribs?? Rowdy Wooden Boat Building and Restoration 8 03-06-2005 01:12 PM
