| infusing a multi part mold How does one go about infusing a 3 part mold.The part lines would be air leaks. Is there a way? Thanks. Fred |
| Envelope bagging for small moulds. Or if that is not possible, I once infused a multipart mould (boat) which had a recess for a line of sealant tape. The mould builder had been thinking BEFORE making the mould. Quite impressive. Also possible but cumbersome is to bag the seam on the outside. Through-bolts then are a concern.
| Thanks Herman Was the recess line in between the flange before the bolts, kind of like an o ring arangement? If so I imagine you lay down the sealant tape in the groove and then bolt together squashing the tape for the seal. If not could you please explain further. Thanks again. Fred |
| The recess should be near to the part. the bolts should be outside of the cavity, as these can only create havock. Trying to make bolts airtight is no fun.
| Oh, there is also some special (reusable seals for them, but these are designed to go all the way round (RTM / RTM light.) where these are used for sealing the top mould on the bottom mould. Creating a subtle end arrangement for these seals is somewhat difficult.
| Two part mold seams | alien8 | Materials | 13 | 07-16-2010 07:31 AM |
| Finish surface from infusing a multi-sided part around a core | Tarek | Fiberglass and Composite Boat Building | 7 | 09-25-2009 09:54 AM |
| Creating a mold from an existing part | Dynafoiler | Fiberglass and Composite Boat Building | 7 | 07-11-2009 09:13 PM |
| Blocking off part of mold | Roly | Fiberglass and Composite Boat Building | 3 | 02-18-2007 09:33 PM |
| Part stuck in mold!! Yikes!! | searaytuna | Fiberglass and Composite Boat Building | 5 | 03-09-2006 03:40 PM |
