Old 05-02-2009, 03:43 PM
m2bueller m2bueller is offline
Rep: 10 Posts: 2
I'm converting a bowrider to a center console.
I recently picked up a 1983 Chris Craft Scorpion 168 (19') bowrider. The floor and transom are solid with no soft spots. The interior was gutted by the previous owner. The plan is to cut out the split consoles and build from scratch a center console. I've been laying up fiberglass since the 70s so the console is no big deal. My question is about the comfortable width of the CC. I've got about 68" between the rails. I would like the build the console as wide as possible but still leave sufficient room to pass by it on either side. Is there a suggested minimum width I need to leave for this?
I'll be posting pics as the build continues.
Old 05-02-2009, 03:53 PM
rasorinc rasorinc is offline
Rep: 678 Posts: 1,127
You can get by with 15" to 18" each side as you do not have to rotate your shoulders. you can test that with 2 pieces of wood in the garage. However if you run your console all the way to one side then leave 24" clear for a 1 way clearance
Old 05-02-2009, 06:25 PM
Rep: 2891 Posts: 8,792
When moving around, fighting an obnoxious fish, that's trying to foul on the drive leg or something, you'll want as much room to dance around the inside of the boat as possible. Make the console just big enough to house what you need and use the room gained for the bigger butted friends you might have aboard.
Old 06-08-2009, 03:40 PM
Rep: 10 Posts: 2
Well I've decided to keep the console under 30" wide. That will leave me plenty of room to move around the sides. Now for my next question. This has to do with the old bow seating area. should I cut the whole thing out and leave a flat deck all the way forward or should I box it in and use it for a raised casting deck? If I removed it then I'm left with only the console and the seat built into the front of it for storage. I have a pair of swivel captains chairs that I was thinking out using but I'm likening the idea of a swing back bench to add some additional storage to the boat.
Mental health is highly overrated.
Old 06-08-2009, 03:45 PM
How you arrange your boat is up to you. I'd have a casting deck with storage below, but to each their own. This will also permit an athwartship bulkhead, which will greatly increase the stiffness in the bow.
18' Bowrider & Center Console Molds for Sale Cottager Boat Molds 3 10-26-2007 05:19 PM
Converting Standard hull into bowrider daveint Fiberglass and Composite Boat Building 24 10-22-2007 12:49 PM
new center console pvfishing Boatbuilding 0 01-12-2007 01:05 AM
Converting to a bowrider Bearded Clam Powerboats 6 03-04-2005 07:08 PM
Converting a closed bow to center console TBarCYa Fiberglass and Composite Boat Building 0 08-31-2004 11:25 AM
