Old 06-02-2007, 09:24 PM
gary1 gary1 is offline
Rep: 33 Posts: 157
Ideal radius on corners for Biaxial
Morning,
When laminating over ply what is the ideal size radius to have on corners when laying fabric, this mainly concerns the chine area where the chines meet the side of the hull. I will be using 450 gm 0/90 (15oz) Biaxial Tape on the seams to strap the hull together prior to laminating it.
Thanks
Gary
Old 06-03-2007, 08:56 AM
nero nero is offline
Rep: 112 Posts: 624
I am using 10 qz biaxel glass. It lays and bonds well over a 14 mm radius. The bigger the radius the less stress on the glass.
Old 06-03-2007, 10:39 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Basically, the bigger the better, Gary.
For wet-layup in ambient conditions with your 450 gsm tape, I'd say 20 mm is great and 15 mm is probably doable. Below 10 mm and you'll get air bubbles trapped underneath unless you vac-bag, the fibre will be too stiff to hold such a tight corner without help.
Old 06-03-2007, 02:22 PM
Rep: 33 Posts: 157
G/Day Nero, Mat
Thanks for the advice the chine panels and sides are made off 6mm ply, so I'm not exactly sure what size radius I will be able to shape that to. But I will try to get it as large as practicable so the fabric can take the bend as easily as possible and lay down on the ply hopefully without any air bubbles. Thanks Again
Stay Safe
Gary
Old 06-03-2007, 09:46 PM
Rep: 112 Posts: 624
You can glue a triangle profiled strip of wood to the inside of the joint between the ply pannels. Then you can radius to your hearts content. Will need to glass both inside and outside of the joint.
Old 06-04-2007, 04:55 AM
Rep: 33 Posts: 157
G/Day Nero,
Mate to late, I've already taken to one side with the electric sander and sanding block looks like it might turn out ok. I'll keep it it mind for next time, although I can pretty much guarantee I will build out of Alloy next time. There's way to much sanding in these composite boats for me.
Thank's again for your'e advice
Gary
Old 06-13-2007, 08:49 PM
mike steiger mike steiger is offline
Rep: 16 Posts: 42
I find that a 3/4 inch radius works well when using the biaxle material and put no stress on the fibers and no voids in the lay up. Hope this helps.
Old 06-14-2007, 01:11 PM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
15mm is fine for most spots. We specify 12mm for most of our fillets. Around stringers and transoms, I go a little larger, maybe 18mm. -- thia woudl be for plywood/epoxy/fiberglass composite.
For foam core, we use trapezoid "hats" of foam which really helps cut down on epoxy use
sometimes the designer will specify, in which case go by that
www.boatbuildercentral.com
Old 06-15-2007, 01:10 PM
frosh's Avatar
frosh frosh is offline
Rep: 44 Posts: 621
There are two other options that havn't been mentioned yet. Firstly if the radius is going to less than 15mm which it will very likely be, what about using regular woven 6oz. tape? Biax is quite stiff and heavy and wont work in small radius curves unless you do the following and maybe get the odd air bubble. I have done this myself and it was fairly successful. I used fairly long pieces of duct tape at 90 degrees to the line of the chine and overlapped the strips a fair bit. It uses a lot of tape and is time consuming but it is almost as effective as vacuum bagging the chine area only. After peeling off the tape once the resin has set, there is still some sanding to do. Regular woven tape of lighter weight is far easier. You need to ask yourself if the biax is really needed for your application?
Am I off the topic yet?
Old 06-16-2007, 12:03 AM
Rep: 33 Posts: 157
Afternoon Mike,Shine,Frosh
Sorry I haven't replied sooner, I had to go fishing for a couple of day's. I ended up putting a radius of approximately 18mm(3/4inch) along the chines and around the transom,after laminating I will fair all these edges back out to a nice clean sharp edge. There are a couple of pictures in my gallery to show the actual radius I ended up with and how far I'am along with my build so far. Frosh your'e right I could most likely get away with a lighter fabric tape but I've got a fair bit of it and just want to use it up. The only real reason I'm even taping it up is to hold the the whole structure together while I'm laminating the hull, at the moment everything is being held together with Epoxy glue /putty and in places I will have to climb on top of the thing whilst laminating it. Thank's everyone for taking the time to help out I appreciate it.
Stay safe
Gary
Old 06-16-2007, 12:29 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 513 Posts: 940
Just adding my 20c worth "cos I use the 20c peice for radius every other day. All the best from Jeff
Old 06-16-2007, 01:53 AM
Rep: 33 Posts: 157
G/Day Waikikin,
Mate thought about the 20 cent piece idea but was a bit concerned about the inflation aspect of the whole thing so I went with the $1.00 coin just to try and keep ahead of it. Yeah yeah I know but I couldn't resist it.
Stay safe
Gary
Old 06-16-2007, 02:00 AM
waikikin's Avatar
Rep: 513 Posts: 940
rampant inflation
Crikey, you get less radius for your dollar every day and even less radius for 2 bucks.Jeff
Radius Chine Hulls Inerested Boat Design 7 02-12-2008 08:04 AM
How to Fillet Corners? S Hondros Boat Design 8 08-29-2006 03:28 AM
When replacing my deck with plywood would 10 oz cloth or biaxial be better baranx4 Materials 2 05-15-2006 08:48 PM
smoothing corners and gel coating problems tropicrows Fiberglass and Composite Boat Building 3 01-17-2006 10:55 PM
mold insert to deal with negative return corners?? Pavook Fiberglass and Composite Boat Building 4 11-28-2005 01:10 PM
