Old 01-01-2011, 04:31 AM
Rep: 1493 Posts: 7,447
The gloss of a marine grade paint is a bit higher than porch paint. That shouldn't make any difference in a canoe. I have painted many boats with regular enamel and got a good finish.
Old 01-01-2011, 09:38 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
One problem is that porch and deck paints come in something like four colors, whereas marine paints usually come in a lot of colors. You won't likely find navy blue, for example, or yellow.
Old 01-01-2011, 10:34 AM
Many paint store carry the paint base and mix any colour in the chart.
Old 01-02-2011, 06:33 PM
mattmartin4 mattmartin4 is offline
Rep: 10 Posts: 11
So going along the enamel / oil based route this would be ideal right?
http://www.rona.ca/shop/~paint-ename...ins_paint_shop
Old 01-02-2011, 10:31 PM
alan white's Avatar
Weeeeeeeellll... I'd recommend you brush the paint on because spray paint actually can be tougher to do well, never mind you'll be using up half a dozen cans. Find an article on "roll and tip" painting and you'll be amazed at the kind of job a brush can do.
Old 01-02-2011, 11:13 PM
Rep: 10 Posts: 11
Hi Alan,
Yes I'm sold that looks like the best route to go. I'll go to my local hardware store and see what they can do for me.
Its going to be at least another week until I paint the canoe. The chip repair is coming along nicely.
Old 01-03-2011, 12:59 AM
Rep: 3125 Posts: 9,399
Given the colors black, white, medium red, medium blue and a bright yellow, I can make any other color. If you're working with straight alkyds, you can buy little cans (half pint?) of the primaries and mix the color of your dreams. You can also get dry pigments intended to do the same thing (actually much better), if you have a need to match colors (which comes up in the restoration business). Naturally, it helps if you are familiar with color mixing. If you know a guy at the hardware store, you can probably convince him to apply a few squirts of pigment(s) into plastic bags, for mixing into your paints later.
Who's right Who's wrong? Is A Canoe Stern Better Performing Than A Double Ender? kudu Boat Design 45 12-03-2011 05:42 PM
Wrong bolts? BHOFM Open Discussion: All Things Boats & Boating 19 08-07-2008 11:42 PM
Wrong Prop? Dan Currie Sterndrives 1 07-16-2007 08:32 PM
outboard height, the right or wrong way tropicrows Boat Design 7 01-16-2007 05:48 AM
