| hull design question. i found a hull on a junk yard, conventional v hull speed ski boat 16 footer. i want to salvaje the hull will separate deck and dispose of it. my question is,,, what changes should i do to the hull to make it a shoalowater skiff ? should i cut a section and make it more flat bottom, and add a tunel in the back. or just the tunnel. im assuming this boat used to have a 70 hp engine or bigger, i will be using a 25 hp outboard so i have to make this boat light. luis |
| If the hull was on a junkyard it was probably there for a reason, I think that you are going to spend a lot more money fixing it than just buying a second hand good skiff hull |
| iknow bu is not about having a boat ,,is about having a boat project. |
| Im building a 32 ft spencer from kit ,got 20,000 in it to repair the same boat I would have 45000 in it , you might be better off with a kit boat ,,,,good luck .longliner |
| Question on Self Draining Hull | jparkes | Powerboats | 1 | 05-20-2005 10:16 PM |
| Hull question | Foiler | Boat Design | 4 | 10-19-2004 10:19 AM |
| Planing hull question | TheFisher | Boat Design | 9 | 12-05-2003 10:14 AM |
| Planing hull question | graham | Boat Design | 10 | 12-13-2001 05:40 PM |
| Planing hull question | graham | Powerboats | 1 | 12-09-2001 05:13 AM |
