Old 09-08-2011, 03:25 AM
thorhawaii thorhawaii is offline
Hull / Deck joint
Hi all ! I have a custom built sailboat and noticed that the deck (plywood) is butted up against the hull and a thick layer of epoxy filler runs the entire length of the hull / deck joint (see photo for example) I was thinking to put fiberglass over the area for additional strength. I guess it's been holding up for the last 30 years but, I could see it separating from the hull eventually. Above deck it's glassed to the gunwales. Does anyone else know of this kind of construction?
Hull / Deck joint-s7301382.jpg
Old 09-08-2011, 03:51 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
If it has been there for 30 years it is well proven, so I would leave it that way.
Sealing wood on one side increases the chance of moisture not being able to evaporate and causing wood rot.
Deck-Hull Joint Dutch Peter Fiberglass and Composite Boat Building 36 02-10-2011 12:17 AM
Delemma-Hull to deck joint Roly Fiberglass and Composite Boat Building 14 03-04-2010 02:39 AM
Deck To Hull Joint VIKING Boatbuilding 16 10-06-2008 07:57 PM
Finishing Hull/Deck joint Jeffrey Boat Design 5 06-19-2005 10:13 PM
Fasteners as well as epoxy at sheer/deck joint? bjl_sailor Wooden Boat Building and Restoration 3 05-26-2005 07:47 PM
