Old 10-22-2007, 12:31 PM
aqua aqua is offline
Rep: 10 Posts: 3
How thick should my powerboat hull be?
Hey all. I have a 12' boat that i am redoing. I have the deck separated from the hull and i am replacing all of the old rotten wood with either nidacore or coosa....havent decided yet. Anyway on the bottom of the boat there was a 1/4" sheet of plywood cut and layed down flat on the bottom of the hull for additional support. My plans are to replace this with a standard stringer setup and I was going to reinforce the hull since it is only around 1/8" to 3/16" thick. What materials and how much could I use to try and keep the weight down to a minimum but still add enough strength to hit a few waves. It will have stringers placed about 12 - 15" apart. How many layers...what ounce....what kind. Would be using epoxy. thanks
Old 11-04-2007, 06:29 PM
parnine parnine is offline
Rep: 4 Posts: 4
buy and read 'the elements of boat strength'
Center of rotation of powerboat hull rascalfair Boat Design 9 02-05-2005 04:33 PM
Search for a Plan of a Powerboat Step Hull Johannes Pinl Boat Design 0 10-29-2004 08:43 AM
A Thick Glass Over Ply Hull? NEILIUM Wooden Boat Building and Restoration 12 10-09-2004 07:03 PM
How thick for window glass Willallison Sailboats 16 08-24-2004 02:02 PM
hull designs on a 17' powerboat curtis73 Boat Design 6 03-15-2002 08:22 AM
