| How Thick Can I Fill with Epoxy over Balsa Cored Fiberglass Floor? I replaced the balsa core on my flybridge floor. I put two layers of glass (biaxial bonded to mat - so I have mat-biaxial-mat-biaxial) using an epoxy resin. I tried to keep everything as flat as possible, but I will need to fill a lot in some areas. I thought about filling the lowest spots with epoxy-milled fiber-cabosil - A mix of about 4 volumes of epoxy, 1 volume of milled fiber and enough cabosil to thicken. Let this set up and then fill closer with just epoxy-cabosil. Is this OK to do? What limits on thickness are there? Should I do several thinner layers?
__________________ Wherever you go, there you are... |
| naturewaterboy, Just how deep are you expecting to fill, if over 3-4mm, you should look at doing some more laminations in the hollowas, then you only have slight detents to fill. Too much filler is never a good thing. It contracts and expands at different rates to the base, and eventually lets go.
| I'll have to measure, but a good point to add layers rather than filler. If I do use filler, does it help to put some milled fiber into the resin rather than use all cabosil?
| I have found that it is better to fair prior to glassing so that the filler is locked in and the outer surface is consistant. This solves the problem of sealing the filler, which saves epoxy. Alan |
| soooo true alan, it is always best to do a job once and do it right, unfortunately that is not the case, so now he has to repair the damage.
| Measuring the worst low spots, looks like I might need 2mm of filler. What do you recommend for filler - milled fiber, cabosil or microballoons?
| Cabosil will work fine, There is alot of info in the links at the bottom of my blog. http://mangomadnessj30.blogspot.com/ |
| Mango, thanks for the link. Good description - you put a lot of work documenting your work. Thanks for sharing. Your project looks a lot like mine. I've taken some pictures but not as many as I thought I would - I usually remember to take a picture when I've got gloves full of resin. I've installed about 30 square feet of balsa core. I haven't finished any of it yet - just trying to get all the rotten core replaced and get it waterproof before we see a hurricane. I have to fill and sand a lot of area. I have done a bit of glass work on other parts of the boat and on several other boats. Sure like sanding epoxy filled with microbaloons, sure hate sanding epoxy filled with milled fiber. But the milled fiber has to be lots lots stronger. I've replaced a lot of deck, and I don't want any cracks after I'm done. I think I'll try to fill as much as I can with milled fiber and cabosil, then try to keep the microbaloons very thin. Does this sound like a good plan? BTW, very fine spousal unit there! Nice photography (her and the boat!)
__________________ hehe ,,,,,Jim------> |
| Polyester resin is not generally compatible with epoxy under it, epoxy over poly is OK, just not under it normally. Therr are problems with the poly not setting correctly because of the epoxy underneath...just be aware of this.
| ya,, i knew not to mix the 2,,,just as we all know,, i dont mess with epoxy,,hehe,,and with poly i know that you dont glass over filler because you end up with cracks there in a few years.,,i just automatically thought it was the same with epoxy,,hehe ![]() thanks LL ![]()
| Change Epoxy traits – fill materials | Slowmo | Materials | 15 | 03-02-2010 04:58 PM |
| Fiberglass Cloth or Fiberglass Mat? Fiberglass Resin or Epoxy Resin? | canoe42 | Fiberglass and Composite Boat Building | 4 | 06-30-2008 09:18 AM |
| Replacing floor in Fiberglass hull | funkyblues76 | Fiberglass and Composite Boat Building | 2 | 03-15-2007 10:43 PM |
| Balsa cored hull? | Itchy | Fiberglass and Composite Boat Building | 36 | 11-21-2006 12:49 PM |
| soft spots in fiberglass floor | LEASEGUY | Fiberglass and Composite Boat Building | 13 | 08-26-2006 10:08 PM |
