| How much glass is in a roll I know there aRE VARIABLES but for example in a roll of 1708 50" wide how much glass by square foot is in that roll? |
| according to here: http://www.shopmaninc.com/cloth.html the length of a roll is generally 125 yards but can vary from 110-130. You are looking at around 1575 sq ft for a roll. Or are you talking weight? If so you need to divide into yardage and multiply by the oz per yard cloth weight. |
| Remember that it is 17oz per sq.yd and .75oz per sq.ft.
__________________ Gonzo |
| So weigh it & do the math if it isn't a virgin roll. Allowing for core. |
| Thanks |
| I bought a kilo of glass the other day, he said it is 300 I dont know what that is but he said it will have about 4.5 sq meter, it is very thin, I was a bit dissapointed how thin actually but at least I can work it which is what I need to do. So does it not depend on the weight of the glass as to how much you get in a roll. |
| Woven cloth I presuime. 1000/4.5= 222gm/m2 222/28.4=7.8oz/m2 which is about 6oz/yd2 which is ok for surfboards or skinning your dingy. |
| Chopped strand mat,--Is that what 300 means --300 grams per SQ meter or 300 miligrams. It is very thin --ive never seen thinner, you can see through it. |
| If aint woven or stitched together with threads as in DB,triax,uni, & it looks like csm as in random stuck together stands then its csm. I 've never heard 300 for a name. And csm comes in oz/sqft. I only ever used it on house roofs. |
| fiber glass roll cutting | bertho | Fiberglass and Composite Boat Building | 9 | 02-20-2012 05:36 PM |
| glass bottom boat, glass type suggestions | terallan | Boatbuilding | 4 | 01-14-2012 03:15 AM |
| Roll and tip? | Sand crab | Fiberglass and Composite Boat Building | 3 | 06-09-2011 10:51 AM |
| Composite (glass/foam/glass) For Beginners? | CatBuilder | Fiberglass and Composite Boat Building | 133 | 11-02-2010 03:27 PM |
| Force needed to roll or counter roll | fer_mayrl | Boat Design | 1 | 02-13-2004 03:21 PM |
