Old 09-10-2008, 10:58 AM
mongo75's Avatar
mongo75 mongo75 is offline
Rep: 95 Posts: 262
How much epoxy do I need for 310 sq ft of cloth?
OK, here's another question yet, sorry but i hate bunching questions in one post.
I need to lay down about 310 square feet of 1708 on my topsides (25' flybridge) so my question is, how much epoxy do I need to to use, being that it's getting rolled on? Thanks!
Danny
Old 09-10-2008, 11:42 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is online now
Provocateur & Raconteur
Rep: 578 Posts: 604
IIRC the easiest method is to weigh your fiberglass and then calculate the same weight of epoxy (for a 50/50 mix of glass & resin). Also IIRC a gallon of epoxy weights 8 lbs. / gallon. The other way to look at it is, your 1708 weighs 25 oz / sq yrd. Your flybridge is approx. 35 sq yrds. You'll need 875 ounces of epoxy which is just about 7 gallons +-. You should figure in a fudge factor of 15% for spillage, wastage & miscalculations like mine! ;-) good luck.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 09-10-2008, 02:54 PM
mongo75's Avatar
Rep: 95 Posts: 262
Damn Rick, you did all the work for me- thank you! Seeing as how I have about 4 gallons, I'll need about another 4 to be safe. Thanks again!
Danny
Old 09-10-2008, 05:05 PM
Rep: 578 Posts: 604
Good luck with your project Danny. Post some pics if you can.
Old 09-11-2008, 05:38 PM
mongo75's Avatar
Rep: 95 Posts: 262
Here's a limk to the latest work I've done to her. I actually installed one of the 4x8 sheets on the roof today, the other will go on tomorrow hopefully...
http://www.bloodydecks.com/forums/ch...vannah-ii.html
And here's a link to show what I started with.
http://www.bloodydecks.com/forums/bo...ight=polyester
Warning, there may be some strong language on these other site's forums...
Danny
Fiberglass Cloth or Fiberglass Mat? Fiberglass Resin or Epoxy Resin? canoe42 Fiberglass and Composite Boat Building 4 06-30-2008 09:18 AM
Fiberglass cloth or not? Barry Beard Wooden Boat Building and Restoration 34 08-07-2007 01:07 AM
Epoxy resin and cloth selection questions sbklf Materials 1 05-03-2006 01:15 AM
Gel coat/Epoxy fibreglass cloth construction mikeboatman Fiberglass and Composite Boat Building 2 04-29-2006 02:06 AM
Cloth over cloth, no mat Koz Materials 13 01-30-2006 06:18 PM
