| How many from mold? Hello, How many hulls can one expect to get from a quality made mold? What does one usually do when this number is reached? Use the prior hull as a plug to make a new mold? Thanks, Jason |
A shower company we pulled 2 a day for the 3 years i worked there . A 36 foot power boat was in the 200 plus whn i left , Got checked and waxed evey boat ! these were old moulds , newer with better resin will last even longer . Abuse will limit there life ! dont look after dont exspect to last real simple . ![]() ![]() ![]()
| What we used to do at TPI is build the first plug boat, take a mold from it, and then take special plugs from the mold in order to make replacement molds. Our molds, for the likes of the J-24 and the Freedom 40, were ventral seamed, so they were two-part molds with the mating flanges down the centerline and then up one side of the transom. The J-24 was available with lots of different stripe graphics, so we striped the inside of the molds, and then the replacement plugs, with alternating colors of orange and black gelcoat in the various striping patterns. Tape off the appropriate color stripe pattern, gelcoat according to the color scheme for the stripes, and then overcoat that with the basic hull color, usually white. Some stripes came with a rainbow of colors, so an owner could really customize the hull. The molds had their flanges and lock keys built into them, so when we did a replacement plug, this was made up of two halves, male shapes of each half mold, with the flanges and lock keys incorporated into them. So the mold was made, and then the plugs were made from the molds and stored for later use to make more molds when the originals wore out. We would generally plan on 300-500 parts coming from each mold. We also were the authorized supplier of J-24 molds to all other authorized builders around the world, so we used the master plugs to make all the other authorized molds. The last I heard, which was back in the 90s, that world wide the J-24 was well over 5,000 units. I don't know what the final count is now. Eric
| Usually about 40-50 hull. If the mold is maintained and properly fastened perhaps 70. AFTER NEED RENEWAL
__________________ m3mm0 SR ib http://www.youtube.com/watch?v=5kwlNk7-iSg |
| It depends on a few different things, size, shape, material it's made from, temperature reached during exotherm, care used in de-molding, storage conditions, mold release, gel coat type (both the mold and hull), plus others. I have customers that go 50 parts before needing to apply more mold release, others do it every time. Typically, the limiting factors in a molds life are how well it was built and how well it has been taken care of. |
![]() ![]() SPECIALLY THE BOTTOM FROMTHE CHINE DOWN
| What i find is that chipped corners , and "wax buildup" are the two factors that "age "my moulds (australian spelling) Also any backside whacking to release (with a rubber mallett) will make ugly star cracks and care must also be taken that any external metal or timber reinforcements do not "print" onto your moulds, If you expect a design change will be needed after a number of parts are sold then there is no point to saving a part as a plug for a new mould. |
| Mold | tasmou75 | Boat Molds | 6 | 01-23-2010 01:09 AM |
| rent 100-110ft mold for sailing yacht? or someone can build hull from own mold for me | gp333 | Boat Molds | 19 | 10-05-2009 08:27 AM |
| trade mold for mold | Fiber-Works | Boat Molds | 2 | 07-28-2009 01:06 AM |
| 14' kayak mold for sale ( vaccumme bagged mold set ) | carboncopy001 | Boat Molds | 2 | 02-05-2009 02:03 PM |
| Off the mold! | flydog | Boatbuilding | 4 | 02-08-2007 10:10 AM |
