| Thanks for the reply PAR. 3 times the current layup is a lot of glass! I may have to get some heavier cloth to use. Otherwise it will take 10 additional layers of the 6oz or 2 woven and two cloth to get the amount you recommend. |
| As I said nevermind what I said. Bear with me, I've just opened The Elements of Boat Stength a couple of days ago and I'm trying to learn something here. ![]() Bulkhead tabbing formula in the book gives a laminate of just 17 oz of fiber. This seems a bit thin to me. The number I posted earlier was for a foam cored stringer, not a plywood one, 4 mm translates to about 90 oz. I think the truth is somewhere in between. Lurvio
__________________ Hopefully creating something useful, since 1983. Last edited by Lurvio : 05-22-2011 at 03:03 PM. Reason: typo |
I'm using epoxy which on it's own has a tensile strength of 7,846 PSI and a flexural strength of 14,112 PSI. I would think that epoxy would allow for less glass to be used. I don't want to under do it and I can add more layers as needed. |
__________________ Time is Gods way to keep everything from happening at once. |
I meant that if somebody could explain to me how much glass I needed I can add more. Either way, this afternoon I spent sanding the stringers in prep for the new layers of glass. I'm going to apply more, I just don't know how much more is going to be enough. I have enough cloth left to give the stringers another 2 layers and still have enough for the sole after that. I guess I will start with two more layers of 6oz cloth and wait to see if there are any more comments on this thread. Cheers and thanks! |
| Can you post pictures of your boat, from the stringers. I won't be able to give you a more specific answer, that is for the more experienced ones. ![]() Lurvio
__________________ Hopefully creating something useful, since 1983. |
| Toss another layer of roving over it and call it a done deal. Without pictures and a whole lot of other information, determining how much you need, impact loading compensation, longitudinal stiffness, etc. then it's all just guess work. |
| I only have pics of what the stringers looked like during the teardown process. My camera died from the dust while I was grinding later. These pics show what the stringer system looked like. I have been replicating what was there as far as structure. You can see that the previous owner did a horrible repair job. The stringers were in sections, joined together using braces and screws with no fiberglass covering. In my repair I did not use braces as shown; I used continuous lengths of plywood. |
| I have restored several similar boats of this vintage and style. In my opinion, Your useage of 24oz woven roving is WAY overkill. PAR is correct in LIGHT is RIGHT and mulitple layers. I would Highly Recommend Three Layers of 1700 Biax cloth and call it good. that is what I have use and NEVER had any issues. The Biax is super strong and easy to work with. The Woven....Not so much.
__________________ I'm just sayin...:-) |
#25
I would agree that biax is the best choice and if there is a next time I will use it. As it is now, I've used the woven roving and cloth to finish this repair and I'm onto the sole of the boat now. The woven I actually found OK to work with as long as you don't try and wrap around 90 degree corners. The cured 24oz roving is really thick and strong. It sure soaks up the resin though. |
| Are 2 layers of wax and 2 layers of release sufficient? | Bill Brasky | Fiberglass and Composite Boat Building | 8 | 07-31-2010 02:14 AM |
| How many layers of fiberglass cloth? | MichaelG | Fiberglass and Composite Boat Building | 17 | 10-19-2007 05:31 PM |
| Cloth over cloth, no mat | Koz | Materials | 13 | 01-30-2006 05:18 PM |
| Stringers and Transom - cloth weight | MercMark | Fiberglass and Composite Boat Building | 5 | 06-13-2005 09:24 AM |
| Stringers and transom - cloth weight | MercMark | Materials | 0 | 06-02-2005 01:10 PM |
