Old 07-09-2011, 04:08 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,866
How to dry wwod
How would you dry some 1 inch marine ply that is encased in fibre glass or does it matter being marine grade stuff.
Old 07-09-2011, 04:37 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,054
How wet it is ? If it's wet throw the inner veneers there's no reasonable way..
Old 07-09-2011, 06:26 AM
sdowney717 sdowney717 is offline
Rep: 77 Posts: 135
likely impossible
if you have a vacuum pump, you could drill a hole and hook it up and let it run for week.
under a vacuum water boils, vaporizes and the pump sucks it away.
it depends how well the fiberglass is sealed as to if a vacuum could be gotten on the wood.
Old 07-09-2011, 06:37 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Bag the whole thing and hook up a shop-vac. Let it run in the sun. How big is the object?
Hoyt
Old 07-09-2011, 07:52 AM
Frosty's Avatar
How much is a vacuum pump?--you mean one of those pumps that vac out air conditioning systems or is that too strong? Those pumps cant run for a week --can they?
If it boils by lowering the pressure isnt there a chance of expansion.
Its in a bulk head,--about 5 feet high by 3 but only wet at the bottom.
It might have come from a self tapping screw holding an auto bilge pump switch !!!!!!.
Old 07-09-2011, 07:56 AM
hoytedow's Avatar
Resistor
Just use a regular shop-vac. You can probably find one cheap if you don't already own one. Hook it up to the screw hole. The water can exit through its entrance.
Hoyt
Old 07-09-2011, 08:00 AM
Frosty's Avatar
Whats a shop vac? ok ile google it --back in a minute!!
Old 07-09-2011, 08:02 AM
Frosty's Avatar
Oh you mean a regular vacuum cleaner, will that do it?
Old 07-09-2011, 09:37 AM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
When you say 'regular vacuum,' do you mean normal shop vacuum, or household vacuum? Household vacuums aren't equipped to handle liquids or wet substances. Shop vacuums are; and they're almost ridiculously cheap -- here in the states, anyway.
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
Old 07-09-2011, 09:43 AM
Frosty's Avatar
Well a regular house vac non wet would be able to handle the small amount of moisture that would take a week to come out.
Yes the wet and dry house vacuums are cheap about 30 dollars. Is that what we are all talking about. You saying that would suck out the moisture?
Old 07-09-2011, 10:40 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
cut it out and replace it ..you know it makes sense .....can you dry out a wet transom ..no ......**** happens live with it .......I do she is called Hilary ..
Old 07-09-2011, 11:03 AM
Frosty's Avatar
There is a difference between wet and rotten.
Old 07-09-2011, 11:04 AM
hoytedow's Avatar
Resistor
Afterwards you can inject some sodium borate.
Hoyt
Old 07-09-2011, 11:37 AM
Stumble Stumble is online now
Rep: 604 Posts: 1,086
To get enough of a vacuum Yo boil the water off at a reasonable temperature you need to pull around 27in/hg which translates to a boiling point of 115f or so. This is well beyond what a shop vac can pull. If this is the rout you want to go you need a much stronger pump (and one that isn't dependent on air flow to cool the motor. Try a refrigerant pump. The threads on vacuum infusion should have a number of good suggestions that run around $100.
Old 07-09-2011, 12:21 PM
tazmann tazmann is offline
Rep: 192 Posts: 218
Frosty
If it is just a small area at the bottom that's wet not rotten, I think what I would do is just drill some small holes it the area 1/8" or so diameter couple inches apart and use a heat lamp close to it and give it some time to dry, after it is good and dry inject epoxy resin in the holes and be done with it. I did it that way on some balsa coring that had gotten wet but was in good shape yet, worked good just took a long time to fully dry
Tom
rejuvinating dry wood Frosty Wooden Boat Building and Restoration 12 04-11-2011 11:13 PM
Floating Dry Dock captraj Stability 5 12-18-2010 08:17 AM
Dry Run inventing_man Jet Drives 1 07-14-2007 03:14 PM
How Long to Dry Wood Boat Wooden Boat Building and Restoration 15 03-25-2007 01:58 AM
wet and dry sanding bojangles Fiberglass and Composite Boat Building 9 04-07-2006 01:15 PM
