| How do you taper a single layer of glass? If something calls for a taper, but you are using only 1 layer of glass, what do you do?
| I have seen guys shread the edges so it would tapper off at the edges after wetting out other than that grinding or filing the edge off after cured Tom |
| I use a belt sander.. uups.. sorry, the belt sander, it's Makita ![]() |
| You can pull yarns, cut them or just grind them when cured. |
| Ah, ok. Thanks, guys. I had been grinding them after they cured when doing lap joints. Now that I'm doing infusion, I wasn't sure how to deal with the laps. I guess I have no choice but to pull yarns and kind of fray the edge to make the lap. Thanks!
| adding glass-layer to existing underwater | simon | Fiberglass and Composite Boat Building | 5 | 12-25-2009 04:40 AM |
| Taper in a birdsmouth mast | dwalker | Wooden Boat Building and Restoration | 14 | 12-19-2009 07:31 PM |
| Transom wedges: Taper down, or up? | nikous | Fiberglass and Composite Boat Building | 2 | 11-05-2008 02:38 PM |
| Transom wedges: Taper down, or up? | nikous | Boat Design | 0 | 11-04-2008 12:27 PM |
| Masthead taper | dreamer | Sailboats | 2 | 08-06-2008 08:44 AM |
