Old 10-26-2010, 09:43 PM
hyboats's Avatar
hyboats hyboats is offline
Rep: 10 Posts: 42
How to connect canopy frame to deck ?
I want to use screws not bolts with washers so the frame will be easy take away and easy for truck delivery.
Should I laminate some stainless steel plates under the deck so it will be much stronger, but I am a little worried about rust and leak.
Any guys have good suggestions ?
Bruce
Old 10-26-2010, 10:21 PM
Rep: 3125 Posts: 9,399
Laminate blind nuts into some G-10 or other backing plate bonded to the deck cap. This will permit you to use machine screws (bolts), which are stronger then wood or sheet metal screws.
How to determine the frame spacing for deck cargo barge using ABS Steel barge rule? jimianbu Class Societies 8 11-22-2010 07:40 PM
how connect center console to deck ? bolts or glue hyboats Fiberglass and Composite Boat Building 8 09-21-2010 07:15 PM
Canopy frame material, aluminium or stainless steel ? hyboats Powerboats 16 09-16-2010 11:01 AM
Attaching Flooring frame to Rib Frame. jeff goldberg Boat Design 0 05-24-2006 01:34 PM
How do you connect SS rigging to an aluminum hull? BillyDoc Metal Boat Building 12 10-28-2005 01:46 PM
