Old 09-12-2007, 08:33 AM
OGM OGM is offline
Rep: 10 Posts: 12
How to bend core
How do you put a bow in core material when building a hard top? I'm going to use 1 1/4 inch thick 5lb divinicell or similar foam core and have a slight bow to the top. The natural sag of the material may be enough, but if not can you heat it with a heat gun or something similar to get it to lay on the mold? I'm sure that vacuum would do it, but I don't have a vacuum pump and may try to suck it down with a shop vac. I don't want to have to relie on that to get the foam to pull down, or am I worrying about nothing. The top is 8 ft wide and has a 2 to 3 inch bow in it.
Old 09-12-2007, 08:49 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
Don't know about divinycell but I've seen core-cell heated to form to a mold as well as screwed to the mold from either side to hold the shape. A vaccum press on a part that size would be a challenge. I've seen it done this way too.
I believe there were sandbags hanging from those loops.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Mast Bend PI Design Sailboats 13 12-07-2006 09:30 PM
Nomex Core granite Sailboats 12 03-08-2006 07:19 AM
Balsa core vs. foam core James Maldonado Fiberglass and Composite Boat Building 23 01-21-2006 10:12 PM
maxsurf problem:density affect the bend moment ageny Software 8 02-21-2005 12:36 AM
Mast bend charasteristics ( dynamic gust response) patrik111 Sailboats 5 08-01-2004 01:23 PM
