| Hole Repair Methods and Materials Had to surgically remove a rotted wood mast cleat from the deck of my FJ and now have a 1" x 3" wide hole straight thru the hull. I can access both sides but not sure if I have to re-laminate all the layers of glass or would a epoxy-based filler work better ? The actual thickness of the keel laminate is about 3/4" if that's a factor. Also, would I be better putting back in a piece of polymer or would wood actually bond better ? Please advise/ help, Thanks Pete |
| Sole repair materials and steps | FisherFanatic | Boat Design | 6 | 09-02-2007 05:23 PM |
| Planking methods and materials | lkomenda | Wooden Boat Building and Restoration | 9 | 08-01-2007 06:01 PM |
| Materials to use to repair holes and Rot | whf1027 | Fiberglass and Composite Boat Building | 6 | 06-24-2007 11:35 PM |
| Seat Base Materials and repair. | Odonor | Boat Design | 1 | 05-05-2006 07:00 PM |
| Screw Hole Repair | Comet | Wooden Boat Building and Restoration | 9 | 04-05-2006 09:47 AM |
