Old 05-14-2009, 07:38 PM
Kaptin-Jer's Avatar
Kaptin-Jer Kaptin-Jer is offline
Semi-Pro
Rep: 206 Posts: 563
Worse case scenario - No insurance, you still are upside down on the payments, and you have a limited amount of disposable income.
If all that is true then you have to become a fast learner. It is duable. It is messy, hard, dirty work, but one thing you have going for you is that almost all the repair work is below the surface so an amateur fairing will not be that noticeable. Try to contact a pro and ask what he would charge to supervise your work, or find a yard rat that can help on the week ends. Look at it as therapy.
Over the years I have spent nearly all of my money on boats, beer, and women. The rest of it I just wasted.
Old 06-05-2009, 03:52 PM
blaze_125 blaze_125 is offline
I see the light!
Rep: 14 Posts: 87
would I be right if I said: "the foam kept that boat from sinking" ?
Old 06-05-2009, 06:11 PM
wardd wardd is offline
Rep: 443 Posts: 925
another way would to tape up the damaged area with aluminum backed tape use a liberal amount of parting or in the old days simonize was used..
make a mold of the damaged area and a good amount of the undamaged area.
pour plaster in the mold and work that till you have a passable plug then make a mold from that.
Old 06-06-2009, 02:58 AM
Stumble Stumble is offline
Rep: 550 Posts: 921
The biggest problem I see with doing this yourself, assuming you realize that it will take months (doing it part time on weekends) to get right is identifying how extensive the damage is. While the hole and delamination is clear, there could be all sorts of things hidden just behind the visible damage. Heck from a hit this hard I would be out measuring the entire boat looking for hull deformation.
My advice is get a pro to do the work with a reputable yard standing behind them. It may cost more money, but if there is a problem later, or something isn't right you have a real business to go talk to about standing behind their work. The other issue with doing it yourself is that unless a qualified person does the work you may have a problem getting insurance or passing a survey later on down the road.
Advice on how to patch a hole in the hull needed please Oldgold Wooden Boat Building and Restoration 9 06-29-2007 10:18 AM
Constraint fitting a fixed shape inside a hull Grant Nelson Boat Design 10 04-21-2006 05:03 PM
Fixed Fire Suppression Sustems Jbrooks Sailboats 0 06-14-2005 04:20 PM
Hole 01pinkfloyd Boat Design 2 05-08-2004 07:16 PM
