Old 11-14-2010, 10:09 PM
mcomikey mcomikey is offline
Rep: 10 Posts: 2
Help with stringer rebuild. Not beating a dead horse !
I have a 1975 Trojan F30 in which I'm about to start rebuilding the stringers. After removing the motors and looking closley at the stringers, I found they had some repair attempted in the past.
There are 4 stringers that run from the transom forward. The center 2 being much larger that the outside 2. I found that at the mid-ship bulkhead, these stringers are not continuous, but rather tie into the bulhead. The bulhead is the continuous form with the stringers tied into it.
My question is this: As they have been repaired in the past, how do I know if this is the original design ? Is that important ? The bulkhead itself is also rotted, so that will be replaced. I am just trying to figure out if I should build the stringers first, then tie in the bulkhead, or the other way around.
Thanks in advance !
Mike
1975 Trojan F30
St. Augustine, FL
Old 11-14-2010, 10:36 PM
mark775
Stringers first, Mike, then bulkhead. Think of it as a spine and ribcage - Yes, the spine is perhaps a little flexible but continuous without breaks or cutouts, which are stress risers. The ribs (bulkheads,webframes) just maintain the shape (a secondary function of bulkheads is to is stop water, fish, fire, fumes, etc.).
That being said, the boat got away with it before and probably would again.
Old 11-15-2010, 04:38 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
...what he says, yep, stringers full length where possible....
Old 11-15-2010, 08:19 AM
Rep: 10 Posts: 2
Tyvm !
beating angle urisvan Sailboats 20 07-20-2010 04:03 AM
How much Horse Power do you think this needs????? Ravencry Boat Design 43 08-05-2009 05:29 PM
transom stringer rebuild dadsretreat Fiberglass and Composite Boat Building 5 04-12-2009 11:14 AM
Dead light snobery? clodgo Open Discussion: All Things Boats & Boating 74 03-20-2008 01:54 PM
Cart before the horse rturbett Fiberglass and Composite Boat Building 1 10-03-2005 05:25 PM
