  #121
Old 12-03-2010, 08:06 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
Originally Posted by kpiazzisi View Post
OK.....what about the sanding question? Is the light hand sanding I did good enough? I don't want to grind the fibers, I think you were the one that cautioned me about doing that in an earlier post.
you are going to figure out a way,sponge backed sanding pad, Red Scotch brite, flap wheel ,there is a way without grinding down the laminate and yes a light sanding.NO shiny laminate.
Slippery when wet.
www.cheetahcat.com
  #122
Old 12-04-2010, 07:14 AM
kpiazzisi kpiazzisi is offline
Rep: 39 Posts: 61
Does the Duratec require that there be absolutely no shinny laminate? What about adding a layer of mat with epoxy resin onto the existing laminate. I think I may have asked this before, but is it acceptable to have some shinny low spots if an epoxy resin laminate will be the next layer? If so, it might be easier just to do a light sanding of the biax (one direction of the biax will be abrated and the other will not) and then put down the mat. I can sand the shiz out of the mat?
  #123
Old 12-04-2010, 10:01 AM
Rep: 84 Posts: 661
Mat? Do a test and see if the binder breaks down in your epoxy,you will still need to give the epoxy a toe hold some scotch brite or the like.
Slippery when wet.
www.cheetahcat.com
  #124
Old 12-04-2010, 12:02 PM
Rep: 39 Posts: 61
The bite would be all the strands of the biax running in the same direction. Those are the high spots that got sanded with a sanding block. The lows are the strands running perpendicular the the sanded strands. I went to Home depot and no scotch bite pad there. I still don't think Scotch brite pad will get into the lower grooves. Again, I thought with epoxy, it would be OK to have some shinny spots on the laminate, since epoxy will bond the the sites that are abrated? I made some fairing compound and applied that to one of the pannels as a test. I lightly sanded the panel and then applied the fairiing compound. I applied it over some shinny laminate (the lows), but this should be OK since it's epoxy ....right?
Help with my restoration. Nida stringers/deck-home-made-fairing.jpg
  #125
Old 12-04-2010, 12:52 PM
Rep: 84 Posts: 661
First of all you are NOT fairing the surface just abrading it and need only to break the shine is all,a sanding block it the wrong tool to use,a soft piece of upholstery foam behind some 80 grit would work better and sanding in the direction of the top glass may allow you to get more surface roughed up.
The red Scotch brite is all I ever used and stuck it on a DA for large areas.
Epoxy does not Chemically bond it needs a mechanical lock.
Slippery when wet.
www.cheetahcat.com
  #126
Old 12-04-2010, 10:13 PM
Rep: 39 Posts: 61
OK....I will try the scotch brite.
  #127
Old 12-06-2010, 06:54 PM
Rep: 39 Posts: 61
I've talked with Cook Composite reps as well as Duratec reps. I think the Duratec is the best bet for getting a polyester or vinylester based product to form a mechanical bond onto a fully cured, cleaned and abbrated epoxy laminate. The rep for Duatec recomended their Vinylester product due to Vinylester being a better moisture barrier under the Polyester Gelcoat. He said I would have less of an issue with Gelcoat blistering with the Vinylester product.
The Duratec product is high build easy sand. I believe I can build up 20 to 40 mills. I would much rather sand surface primer then sand the epoxy fairing compound. The fairing compound I applied to my test panel a couple of days ago was difficult to sand. I have a lot of areas on the inside of the hull above the floor that are very rough. The high build primer may smooth this out (once block sanded).
I think I am just going to go with the duratec and finish with the Gelcoat sprayed out of a dump gun.
  #128
Old 12-06-2010, 08:06 PM
Rep: 84 Posts: 661
They (Hawkeye)have a 005 White in a VE primer ,if you are going white it would provide a good base also with the gelcoat you can spray a nonskid as well,use a Griptex Fine and it will spray through a paint spray gun.
Slippery when wet.
www.cheetahcat.com
  #129
Old 12-07-2010, 06:04 AM
Rep: 39 Posts: 61
non skid
Yes, I am going with white, so that will probably be the one I use. Good to know that I can spray grip tex. I was wondering about how to do that, because most of the time the gelcoat needs to be color sanded and buffed out....right? Color sanding the non skid would just make it flat and defeat the point of using non skid.
Maybe build a base without the non skid. Then let it dry and wet sand with a 220 or 320 sand paper. Then apply the final, thinner coat with the non skid additive?
  #130
Old 12-07-2010, 08:25 AM
Rep: 84 Posts: 661
You could knock it down with 180 under the nonskid,if you are leaving a brite area around the perimeter or making a pattern, then you have to of course sand and buff/tape off those places before spraying the Griptex.
Slippery when wet.
www.cheetahcat.com
  #131
Old 12-07-2010, 09:33 PM
Rep: 39 Posts: 61
Have you seen the flex mold by Glibco. MAS epoxies is the retailers who sells the product to the public. I think I am going to go this route insted of the grip tex stuff.
http://www.youtube.com/watch?v=aoOtHe4g9m0
  #132
Old 12-08-2010, 09:16 AM
Rep: 84 Posts: 661
We have been using that for years on tooling ,making small repairs is no problem ,But creating Non skid over large areas is a different story with gelcoat and a squeegee.
Slippery when wet.
www.cheetahcat.com
  #133
Old 04-17-2011, 08:40 PM
Rep: 39 Posts: 61
I am back at it.
Foam - I have placed the two part foam in most of the floor (back section left). The
Transom - I used 3 layers of the Coosa Blue water with two layers of 24 oz roving over that.
Motor Mounts - I made these out of wood. I am not crazy about putting wood back into the boat after spending so much money avoiding wood, but I wanted someting sturdy. I am looking for some opinions on these. I haven't decided if I want to use them. I still can do go fiberglass/composite on these if I change my mind. I could make the sides out of two layers Nida with a very thick laminate on both side. The tops of the mount could be a pourable transom material. I could then laminate the whole thing. What do you think. The wood mounts are already made, but if you all think it's tacky (like I do) then let me know.
Help with my restoration. Nida stringers/deck-finished-transom.jpg  Help with my restoration. Nida stringers/deck-shaped-motor-mount.jpg  Help with my restoration. Nida stringers/deck-floor-screwed-down-temp.jpg
Sole ( deck ) and stringers replacement HELP Bermack Boat Design 3 06-08-2007 03:50 PM
Sole ( deck ) and stringers replacement HELP Bermack Fiberglass and Composite Boat Building 1 06-07-2007 07:34 PM
Stringers / Deck / Coosa BW26 Harnesscreek Boat Design 1 10-13-2005 12:01 PM
using composites in stringers and deck Guest Materials 13 07-19-2004 12:55 PM
Nida core Eagle Boats Fiberglass and Composite Boat Building 0 04-23-2004 10:18 PM
