Old 04-03-2010, 06:30 PM
aggiefan07 aggiefan07 is offline
Rep: 10 Posts: 2
help motor mount help
i new at this i just got my grandpas old malibu ski boat an the motor mounts that bolt into the fiberglass are broken so what do i do i have pics ill fig out how to post them on here someone plz help
[IMG]C:\Documents and Settings\compter\Local Settings\Temp\Temporary Directory 1 for multimediamessage (2).zip\29424208[/IMG]
[IMG]C:\Documents and Settings\compter\Local Settings\Temp\Temporary Directory 2 for multimediamessage (2).zip\29432576[/IMG]
[IMG]C:\Documents and Settings\compter\Local Settings\Temp\Temporary Directory 3 for multimediamessage (2).zip\29437136[/IMG]
Old 04-03-2010, 06:35 PM
Rep: 10 Posts: 2
here they are i think
help motor mount help-boat1.jpg  help motor mount help-boat2.jpg  help motor mount help-boat3.jpg
Old 04-04-2010, 04:14 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
I cannot really judge from the pictures, but:
1. If it is the rubber mount that is broken, the fix is relatively simple: replace the motor mount itself. Can be fiddly, but nothing too bad. Do not forget to re-align the engine after replacing the mounts.
2. For what I can see from the pictures, your engine girder once consisted of wood, glassed over with a thin layer of glass. For some reason, the wood got wet, and rotted.
This can be a more or less nasty repair. A lot has been written about it on the forum. In any case, replacing the old structure is the key.
Before any repair, check other spots for damage as well. This sort of damage never comes alone, and in many cases just buying a used, perhaps battered or locally damaged hull could be quicker and cheaper in the end. (considering your engine is still OK, buying a boat with a jammed engine could be really nice)
Addition of motor mount to stern schlever Fiberglass and Composite Boat Building 2 07-14-2009 04:07 PM
Rotten stringer under motor mount Thundercraft Powerboats 4 06-19-2007 10:17 AM
How to mount motor mrgoody Outboards 2 10-03-2006 01:01 PM
Motor Mount Repair - Rotten Stringer DKUDDES Boat Design 4 07-30-2006 08:47 PM
pontoon motor mount kcard2112 Boat Design 1 05-11-2005 09:43 PM
