Old 10-30-2010, 12:21 PM
WyattG WyattG is offline
Rep: 10 Posts: 3
Helm/ Dash restore
i have a late 80's early 90 fiberglass speedboat and i want to freshen up the dash/helm.
it appears that the white gelcoat was painted in flat black by the mfg (it was the in-thing during that era for this type of vessel) and i want to redo.
What are my choices and what are your recommendations?
Not sure if i want to deal with gel coat. I have repainted my bilge in awlgrip and it came out well about 4 years ago but the dash/helm is a different story as i would like to have a nice shinny smooth finish.
can i roll this type of paint on (i know it sounds tacky) or will i need to spray.
Also, should i worry about the work during this time of year. Even though my local temp is very mild compared to most, my temps for the next 60 days will dip as low as 50, but then in the 20-30's in Jan. CAn i start now or should i wait?
Thanks
WG
Old 10-30-2010, 02:04 PM
Rep: 3125 Posts: 9,399
If you want a smooth paint job then the prep is the key. You'll need to block it down, fill any low spots, knock off the high spots and the usual prep for a good paint job. If we're talking about just a instrument panel or other small area, you're best bet would be aerosol paint in a can. Most of these dry quickly enough to take advantage of a fairly warm day. You can also keep an area warm with a small tarp and a heater.
You can use a technique called "roll and tip" though a well handled spray can will have better results in most cases on a small area. Personally, I wouldn't pother with an LPU (Awlgrip and similar), besides you're not going to need anywhere near a quart, so a lot of costly paint will be wasted. A single part polyurethane will do just fine and cost a lot less.
Old 10-30-2010, 04:01 PM
Rep: 10 Posts: 3
PAR,
spray can it is.
any suggested Polyur mfg better than others?
thank you
Livin in fascination daily
Old 10-30-2010, 04:59 PM
Stick with the major brands, but no I don't have a particular preference.
Old 11-08-2010, 05:49 PM
missinginaction missinginaction is offline
Rep: 417 Posts: 336
I'd agree with the "paint in a can" approach. I'm thinking that since this is a dash panel why not use some automotive touch up paint and clear coat it? I've had good luck with some of the online suppliers of auto paint or you could just go to a dealer and order a can of primer, a can of basecoat and a can of clearcoat. Probably cost less than $50.00
My 1996 Chevrolet Suburban still shines after sitting ouside for most of the past 14 years. It's clearcoat has been subjected to a lot more UV than the dash panel of a boat ever would see (since I'm assuming the boat will be covered). I do take good care of my old truck but modern automotive paints are very durable.
FWIW, I've used leftover Interlux Epoxy Prime Coat (404) as a primer on my truck and overcoated with autobase and clearcoat with excellent result. I rolled and tipped the Interlux and then sanded smooth down to 600 grit. Shot it with base coat and clear and bingo.....done.
MIA
New Corsair Dash sea trials Gypsie Multihulls 0 01-15-2009 05:55 AM
How to build/where to get marine dash? Brylk1830 Boat Design 1 04-15-2008 09:43 AM
My Carbon Fiber Dash brainsboy Boatbuilding 10 04-09-2006 11:35 AM
Custom fiberglass dash board??? gbaaron Powerboats 6 08-13-2005 01:03 AM
Dash Design _ electronic Flaws Shawnee1 Powerboats 2 06-15-2004 01:00 PM
