Old 04-02-2008, 01:24 PM
GWB GWB is offline
Rep: 10 Posts: 67
Heavily oxidised hull, what grit paper before painting?
Need to get rid of the oxidisation before painting.
Thanks for any help
Old 04-02-2008, 04:40 PM
grady's Avatar
grady grady is offline
Novice
Rep: 70 Posts: 459
Gritty
Hi GWB, generally speaking if there's no damage to the surface you can start with 120 then 220 then 320.
But if the surface is resisting (taking too long) you could begin with 80, just keep the DA flat and try not to stay in one spot too long.
I'm just a beginer also but I've got some great tread's do a search for awlgrip.
one's titled "orange peel" another "awlgrip knowledge challenge" There's good stuff in both but you may have to sift through some chatter.
Good luck
Fair winds & calm seas
Painting over an epoxy coated hull Jason Connellee Fiberglass and Composite Boat Building 3 07-31-2006 10:34 AM
painting hull - covering Print Through superfly Fiberglass and Composite Boat Building 4 06-16-2006 07:29 AM
Hull Painting Cliff Ruckstuhl Materials 9 09-25-2005 01:26 AM
Painting a Wooden Hull Guest Boatbuilding 1 09-23-2003 10:11 AM
painting hull Sgray Boatbuilding 3 05-16-2003 02:04 AM
