| BTW do you have plans or blueprint of one hard top? |
| The top I described has no foam core. It depends on the tubular frame for support. If a core is used it would be bedded in right after removing the peel ply. The inside finish would then be one 1-1/2 oz mat and the 10 oz cloth. You will still need a support frame of some kind to attach the top to. In your case I presume a curved surface which in itself is strong. A frame is still needed though. |
| Yes, you are right it will have a tubular frame |
| Wellcraft, It's hard for me to believe there is no foam in PR. check further. If you find liquid 2/3 # density foam you can make a tray from 2x4s and poly to pour a bunch. after it gets hard you can slice it as you want. |
| Comments on my building methods (hardtop construction) | DNSeal | Fiberglass and Composite Boat Building | 10 | 12-16-2005 08:15 PM |
| 1972 Hardtop - Stringer and glass | campbell | Boatbuilding | 2 | 06-24-2005 11:51 PM |
| hardtop for cat | captjohn360 | Boat Design | 2 | 12-13-2004 11:26 PM |
| another hardtop | captjohn360 | Fiberglass and Composite Boat Building | 1 | 12-12-2004 08:16 PM |
| Hardtop Construction | cgorton | Fiberglass and Composite Boat Building | 8 | 04-25-2004 05:12 PM |
