Old 01-30-2003, 05:37 AM
andy_s andy_s is offline
GRP finish
I am new to boat-building, and am considering building a small catamaran from GRP on a plywood core.
Whilst I have an understanding of laying GRP into a mold, I do not know how to get a smooth finish when building it up over plywood.
Any advice would be appreciated!
Old 01-30-2003, 01:07 PM
Rep: 1397 Posts: 7,216
It takes a lot of sanding; just like preparing a plug to make a mold of. After you finish laminating, put fairing compound over the whole thing. Then you sand with longboards until it is fair and smooth. There are several methods, but all require lots of elbow grease.
Old 01-31-2003, 02:41 AM
Yup -- like gonzo says, lots of hard work and many many hours sanding. And then after that, some more sanding to get it perfect.
I've done lots of this myself. Recently though I've started to hear talk about the dangers of sanding fiberglass and even that forced air respirators are the only safe way to go. True? If so, I'm probably a gonner by now
choice of finish/ choice of lumber Wood Butcher Wooden Boat Building and Restoration 2 01-09-2005 03:22 AM
GRP Hull Project Help? David Cowen Fiberglass and Composite Boat Building 12 09-27-2004 02:12 PM
GRP basic reading mmd Fiberglass and Composite Boat Building 5 08-21-2004 10:24 AM
Finish varnish coat DavidJ Wooden Boat Building and Restoration 0 06-20-2004 09:38 PM
Wooden Topside Finish CrazyJane Wooden Boat Building and Restoration 3 05-31-2004 07:26 AM
