Old 09-20-2005, 09:40 AM
rturbett's Avatar
rturbett rturbett is offline
Rep: 35 Posts: 139
Graphite Hulls
I've used graphite powder with epoxy to finish rudders and daggerboards for racing. I am told this reduces friction and adds strength. Wouldnt it be beneficial to do this to the catamaran hulls as well? What are the downsides to this? (other than having one choice of hull color- black!)
Rob
Old 09-20-2005, 07:50 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Reduces friction, perhaps, since you can smooth it much more readily. In powder form it won't add much strength. Fairing the hulls can be advantageous if they currently have imperfections, but mixing graphite powder with glue will not give you a carbon-fibre hull. So if your hulls are less than perfect it might help hydrodynamics, but will also add weight. You will not realize an increase in hull strength.
Old 09-21-2005, 06:31 AM
Bergalia's Avatar
Bergalia Bergalia is offline
Rep: 254 Posts: 2,517
Graphite hulls
And it will leave nasty black marks on the ocean floor if you sink
Old 09-21-2005, 03:27 PM
rturbett's Avatar
Rep: 35 Posts: 139
Matt,
I do realize that it won't add strength the way carbon cloth may, but it does seem like the epoxy with graphite is a harder outer surface than just epoxy alone- and it smoothes oh so nice. If I'm finishing with three coats of epoxy anyways, I thought it might be worth doing.
Bergalia,
I was actually expecting brown marks somewhere else from going soooo fast!
Give my regards to Lady Eliot Island!
Old 09-21-2005, 03:37 PM
rturbett's Avatar
Rep: 35 Posts: 139
OOOPS-
L.E.I is Queensland- sorry-
Sydney was great too!
Old 09-21-2005, 05:34 PM
marshmat's Avatar
Yes, it would be a harder outer surface. More brittle, too.
The reason for doing this is precisely because it smooths so nicely. The technique allows you to fair the hulls very smoothly. This is the only reason I know of for doing this.
Old 09-21-2005, 07:36 PM
Bergalia's Avatar
Graphite hulls: rturbett
Originally Posted by rturbett
OOOPS- Sydney was great too!
Right state - wrong area. Us way down south on the coast near Victoria look on Sydney - to quote Billy Connolly: "is where if you were giving Australia an enema, you would apply the tube..."
It's a BIG country, has even scared the 'brown streaks' out of Texans. Please come and visit some time. As a country, it's addictive
Old 09-21-2005, 08:07 PM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Adds strength of any consequence? No. Reduces friction? No. (no-slip condition near surface) Potential corrosion nightmare? Yes.
If you want a hard surface, I'd recommend Pro-Line epoxy primer, but, if you don't sand it out the first couple of days after application you'll be hating it.
Yoke.
Old 09-22-2005, 02:11 PM
wet feet wet feet is offline
Rep: 99 Posts: 264
I might be showing my age here by admitting that I can remember when a paint company that is no longer in the boat market brought out Graphspeed.It was originally used on the British contender for the little America's cup in the late sixties.In essence,it was a graphite powder bound together in paint form and the idea was that if you finely sanded the dry coating,you had a smooth and low friction surface.
Old 10-16-2005, 04:31 AM
dog dog is offline
Rep: 10 Posts: 4
Yup, showing your age there!
Old 10-19-2005, 04:15 PM
unhippy unhippy is offline
Rep: 10 Posts: 10
Rob
The black hull color may be the biggest reason for NOT using graphite.
Black absorbs light and converts it to heat energy which, under extreme conditions, could raise substrate temps to the point that will severely weaken your epoxy. Just passing on some second hand info. I haven't actually seen this myself allthough it does seem feasible given the low melting point of most epoxy systems.
unhippy
SO WHAT? My dog still loves me!
Old 10-20-2005, 12:50 AM
Deering Deering is offline
Rep: 14 Posts: 219
Not sure how much effect graphite will have on water friction, but it's sometimes used on the bottom of river drift boats that scrape over rocks in shallow rivers to reduce friction. I'm told it works well. Might not make your rudder faster, but if you hit bottom...
Have also heard of it being formed up in an epoxy matrix as a shaft bearing surface, either as an emergency repair or in an odd, inaccessible location.
The Ideal Cruiser - a long range passagemaker D'ARTOIS Projects & Proposals 306 07-15-2011 06:54 AM
Radius Chine Hulls Inerested Boat Design 7 02-12-2008 07:04 AM
ROCAT closed mould one-piece hulls cristofa Fiberglass and Composite Boat Building 10 07-15-2005 04:13 PM
A Tale of Two Hulls.... BCBoater Boat Design 6 09-05-2003 01:48 AM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-25-2002 11:26 PM
