Old 03-12-2010, 04:35 AM
shakey78 shakey78 is offline
Rep: 10 Posts: 33
Gluing fibre glass and Carbon Fibre
Just a few questions, if I was to glue hull to the top half (cabin) like a two part molded boat what glue would you use for that application for both carbon fibre and fibre glass
Old 03-13-2010, 01:27 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Either epoxy glue paste (whether or not rubber-toughened) or methacylate glue.
Depending on the situation, one can fillet and laminate the inner and possibly also the outer corners. But that is a bit hard to determine without more info (as in a drawing or photo)
I do not recommend any material, as I have no idea what is available locally. Over here I would recommend either Plexus (MA glue) or Sicomin epoxy glue and resins, or Hexion epoxy glue and resins.
Old 03-13-2010, 06:12 AM
Rep: 10 Posts: 33
I wish to glue top and bottom together, like they do with jetskis I've seen it
done on the how it's made TV show, I would like to have a strong joint
Old 03-13-2010, 01:04 PM
Herman's Avatar
Resininfusion.info
Any photo or sketch?
Old 03-14-2010, 08:25 PM
Rep: 10 Posts: 33
http://www.youtube.com/watch?v=aoXnl2BIa3k
This is what Im trying to do as Im making a small scale model of the boat first
so I wont be able to get to the join on the inside so gluing it would be easyer option just wanted to no the best glue
Old 01-17-2011, 05:12 PM
CutOnce CutOnce is offline
Rep: 205 Posts: 470
The "How it is Made" TV show is a Canadian production out of Quebec if we are talking about the same one. They did a segment on SeaDoo watercraft made by Bombardier in Quebec. The adhesive they use is Plexus MA.
Plexus joints are very strong - surface prep is important, and you should read the Material Data and Safety sheets available where ever the product is (legitimately) sold. You should wear proper gloves that provide a chemical barrier while working as well as it never hurts to use a respirator.
CutOnce
Old 01-18-2011, 01:34 AM
Rep: 3125 Posts: 9,399
Plexus is a fairly complex adhesive system and a two part methacrylate usually. It's important to use the right "Plexus" product (there are several). These fall into several categories, but they are either 1:1 or 10:1 mix ratios. They're priced about like the high end urethanes, usually higher then epoxy and tough adhesives, though epoxy formulations can easy exceed the usual offering from these reactive acrylates.
It's not necessary to have this type of joint on your boat. Mechanical fastening of a bedded joint will do as well and likely cost a lot less too.
In your application the least costly but permanently adhered method would be a polyester grout, with maybe some fasteners. Next would be a vinylester grout, or you could use an epoxy bond, which would likely have better physical properties the the Plexus.
Lastly, cabins occasionally have to be removed for repairs. In this vain most designs have the cabin molded into a cap or if not possible, a raised flange or landing area for the cabin to sit on, so water can't get under the joint, but it still can be separated for repairs, over the road transportation, etc. In this regard most are mechanically fastened over bedding compound with often is polyurethane.
Carbon Fibre Masts Wynand N Boat Design 64 05-05-2008 12:26 AM
Carbon Fibre Unidirectional cloth Ramona Sailboats 8 09-23-2007 02:53 PM
carbon fibre rudder shafts jamesa Multihulls 14 04-21-2007 02:09 PM
Books on Carbon Fibre Spars MikeK101 Boat Design 2 11-05-2006 10:09 PM
Building a Carbon Fibre mast mojounwin Boatbuilding 7 10-27-2005 02:40 AM
