Old 08-19-2006, 10:23 AM
jfc6570 jfc6570 is offline
Rep: 10 Posts: 4
glassing a steel deisel tank?
just purchased a 1977 36 pacemaker , converted to deisel 3 years prior , when purchased old owner thought rear tanks leaked, becuase bilge had deisel in it . have not preasure tested yet , but tanks look very good outside with no visable leaks , my questoin is for peice of mind can i remove the tanks and incase them two or three layers of glass ? i have done many projects with boats and glass , and also ask friends in the buisness , and every one just kinda scratches thier head with no difinative answer.
thanks
jim
Old 08-19-2006, 10:49 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
I'd advise against glassing the tanks. The fibreglass will tend to trap water against the steel, creating near-perfect conditions for rust to spread like wildfire.
If you take the tanks out, you can inspect them pretty thoroughly. Small leaks might be repairable but if there's significant rust, they deserve replacement.
Old 08-19-2006, 11:00 AM
Rep: 10 Posts: 4
i thought of that too , with the aspect of condinsation , my concern with a patch is popping off , my cousin retired chief bosun c.c. said they weild steel diesel tanks all the time , and for rust i detected none , and the inside
" should " not have any because diesel is a lubricant , maybe a preasurization will tell me more ?
Old 08-19-2006, 11:07 AM
Toot Toot is offline
Rep: 17 Posts: 274
You don't have to just slap a patch on the outside of the tank. You can drill or cut a hole, cut a patch to match, tack weld it into position, and then go all the way around. When done, it'll be pretty much as good as new and should be fairly flush.
Fiberglass seems like a losing proposition in this case. And, heck, I'd bet welding would be cheaper. You could probably get it done for maybe $50 as a carry-in/carry-out job at a local auto restoration shop.
Do a pressure test. A gas cap, a bicycle pump, tire gauge, a tap, a valve stem, and some teflon tape is all you really need.
It could just something dumb like a leaky cap allowing vapor to escape and condense on a surface outside the tank before dripping down into the bilge water.
Are we off-topic yet?
Old 08-19-2006, 11:12 AM
marshmat's Avatar
No rust on the outside? The diesel in the bilge is probably from a bad cap or fitting somewhere then. The pressure test will help confirm the tank's condition. As Toot says, it's not hard to repair steel.
Old 08-19-2006, 11:28 AM
buckknekkid's Avatar
buckknekkid buckknekkid is offline
Rep: 37 Posts: 345
Weld the sucker !
Can anyone spare any gas today for a hamburger on Friday ???
Old 08-19-2006, 11:41 AM
Rep: 17 Posts: 274
Originally Posted by buckknekkid
Weld the sucker !
But drain the gas out first!!!
(don't ask me how I know this....)
Old 08-19-2006, 12:05 PM
Richard Hillsid Richard Hillsid is offline
Rep: 19 Posts: 117
Actually …. Fill it up with inert gas or water first, I imagine even filing it up with gasoline would be safer than welding an empty tank they blow easy as the gas to oxygen ratio is better for igniting, the gas comes from the last drop you could not get to drain out.
Old 08-19-2006, 06:28 PM
marshmat's Avatar
Good point Richard.
ALWAYS purge a fuel tank with water (no common gases will fully displace fuel vapours) before working on it. Even something as innocuous as tapping new threads for the sender gauge can create enough of a spark to blow the thing up.
Old 08-19-2006, 07:53 PM
jimslade jimslade is offline
Rep: 27 Posts: 304
if you want to glass make sure you use epoxy and cloth even if you have a pinhole later you will have a safety backup.
Old 08-22-2006, 05:39 PM
Rep: 10 Posts: 4
thanks everyone , preasure test first , then remove
"they are 180 gal a peice" , and weld , if needed , i have rebuilt boats for almost 20 years , it is really nice to be able to get second opinions , i have found one thing the internet is good for
Old 08-22-2006, 10:11 PM
lazeyjack
do you know how to press test?
when we get survey we always use manometer, which is simply a loop of clear tube half filled water, put 2psi in tak, and watch water go up in the second half of loop, should rise to 8 feet head, ok, then leave it settle, on cold day water will drop and hot will rise, but water should stay there, if drops and drops and drops , hey your tank it not tight,
i had to do this for all my yachts in survey, same way they test a liferaft!!
no good just testing soap and water, this will find the big leaks, only manometer will be a true test
no charge for this info)
Old 08-22-2006, 10:12 PM
lazeyjack
oh you,ll need valves in line , just one at hose to tank!!
Old 08-23-2006, 12:38 PM
Rep: 10 Posts: 4
thanks much
Volvo Turbo Deisel CaptPPan Powerboats 24 05-05-2008 06:34 AM
Bait tank/ holding tank fabrication question searaytuna Fiberglass and Composite Boat Building 20 11-17-2005 04:56 PM
Glassing Lapstrake jeff goldberg Boat Design 4 08-11-2005 12:47 PM
Stainless steel (feul)tank Danielsan Fiberglass and Composite Boat Building 41 02-15-2005 02:50 AM
Need help on glassing John Case Boatbuilding 4 02-14-2005 01:10 PM
