| glassing in plywood deck replacement Hi I am currently in the process of refurbing a number of old displacement boat, the boat have all been left for a number of years and are well rotten! Basically all the boats bulkheads bearers and engine beds have now all been replaced and I am onto the deck having cut it all in today I am just wondering what the options that I have not considered are. To provide the strongest long term solution do i need to cover the underside of the deck in a layer of chopstrand and then flow coat it? or can I treat it in some other way that will be quicker? I will of course be taping the top and laying a couple of layers of 2oz csm on the top and same with the taping. Basically I am just after another opinion? My favourite way of finishing decks is flowcoat with a kiln dry sand in it as it provides alot of grip and I think it looks quite smart but does anyone have any other techniques they like to try? These are the first smaller boats I have worked on for a while having only really worked on really big stuff! what lay up would you have used for the engine beds to the hull to support a 3 cylinder volvo? you can never be to careful and is fully braced with other bearers anyway and will also have the floor glassed to the sides but just thought I would ask! There seems to be alot of knowledge on this forum and thought I would ask you guys Many thanks |
| 2oz is really light. I assume you are talking of polyester resin. In new plywood it will be better to use cloth and epoxy. You only need to epoxy the bottom. However, if it is an old construction boat, you first need to consider how it was built so the repair doesn't cause more damage than it fixes.
__________________ Gonzo |
| Deck replacement question - Plywood fit? | thill | Fiberglass and Composite Boat Building | 15 | 02-28-2012 01:47 AM |
| glassing in plywood deck replacement | mark.k | Boatbuilding | 0 | 01-17-2011 02:30 PM |
| What oz cloth for glassing over 1/2" plywood? | mosquitolaGOON | Fiberglass and Composite Boat Building | 6 | 04-19-2008 08:29 AM |
| planking or plywood and glassing a hull | verboon | Boat Design | 13 | 02-08-2008 10:28 AM |
| Glassing Plywood | tie phoon | Wooden Boat Building and Restoration | 10 | 02-11-2007 03:40 PM |
