#46
| The polyester resin was designed for this type of a project, a trial project to see if the design works, many may be made before a final design is established, using epoxy and expensive foam to make mock ups or throw away parts is a waste of money. Epoxy will be a better choice for production in most cases, at least in this application, but for other items the polyester may work well in production. Plugs are also made this way, low cost foam and easy to work with polyester resin allows for affordable and fast tooling options. |
| glassing the outside of canoe | resatch | Fiberglass and Composite Boat Building | 5 | 11-12-2009 02:33 PM |
| glassing in chainplates | bluwateronly | Sailboats | 13 | 02-11-2008 12:50 PM |
| Glassing Spars | lewisboats | Wooden Boat Building and Restoration | 6 | 08-07-2007 07:34 AM |
| Glassing Plywood | tie phoon | Wooden Boat Building and Restoration | 10 | 02-11-2007 03:40 PM |
| Need help on glassing | John Case | Boatbuilding | 4 | 02-14-2005 01:10 PM |
