Old 05-25-2009, 10:21 PM
resatch resatch is offline
Rep: 10 Posts: 3
glassing the outside of canoe
I am almost finished with a 16' lapstrake canoe. I used luan plywood and want to cover the entire outside with 6 oz glass/epoxy. Can anyone lead me to pictures, directions, advice on how to deal with the glass at the ends. Do I cut and overlap? Should I cut darts where it wants to bend? Any help is appreciated. Thanks.
Old 05-26-2009, 08:49 AM
alan white's Avatar
Rep: 1168 Posts: 3,269
More importantly, how do you wrap the glass around the strake edges and make it stick? The other questions are easily answered, though I'll defer to the experts who work all the time with glass.
I suspect you may end up not glassing the outside at all. Glass doesn't stick well to small radii. Especially thicker glasses.
Old 05-26-2009, 09:09 AM
Rep: 10 Posts: 3
glassing the stake edges
Alan,
I treated the stake edges with a flat fillet. I did the same on the inside and it worked very well. I used 3 oz cloth on the inside and it laid down nicely. The biggest challenge on the inside was getting the glass to stay on a vertical surface, but once it was wet it wasn't a problem and I did it in four patches. I want to be able to cover the outside with one piece of class, I just don't have a good solution for the ends---yet.
Old 05-26-2009, 09:34 AM
daiquiri's Avatar
Engineering and Design
Rep: 2340 Posts: 2,472
http://www.greenval.com/FAQglassinside.html
http://www.laughingloon.com/epoxy.html
Old 11-12-2009, 01:27 PM
Rep: 10 Posts: 3
Finished Lapstrake Canoe
I posted questions on this forum as I built the 16 foot Sassafras Lapstrake canoe. I'm finished and wanted to share some pictures. You might be able to tell where I got my Ph.D. from by the color schema. Thanks to everyone who answered my questions.
Follow the links below:
www.ilstu.edu/~resatch/GOIllini.jpg
http://www.ilstu.edu/~resatch/FinishedCanoe.jpg
http://www.ilstu.edu/~resatch/LapstrakeCanoe.jpg
Old 11-12-2009, 03:33 PM
apex1
here:
http://www.newfound.com/rangeley17.htm
--construction notes--
you can find some nice info.
Regards
Richard
glassing in chainplates bluwateronly Sailboats 13 02-11-2008 01:50 PM
Glassing Plywood tie phoon Wooden Boat Building and Restoration 10 02-11-2007 04:40 PM
Fairing and glassing Helmsman Wooden Boat Building and Restoration 2 01-02-2007 10:25 PM
Glassing Lapstrake jeff goldberg Boat Design 4 08-11-2005 01:47 PM
Need help on glassing John Case Boatbuilding 4 02-14-2005 02:10 PM
