Old 08-19-2005, 11:16 AM
Gone Ballistic Gone Ballistic is offline
Rep: 10 Posts: 14
Glass Tissue
Hi,
Another dull question.
I hear many people saying that the fairing process is one of the worst parts of amateur boatbuilding. Will laminating a very light fabric/tissue on the outer layer (building over a tempoary male mould) make the surface smoother therefor requiring less sanding/fairing.
Any other ideas would be interesting,
Cheers
Andrew
Old 08-19-2005, 12:33 PM
Rep: 1397 Posts: 7,216
No. If you want fiberglass buildup in the outer layer, mat is the proper material. The sanding while fairing cuts into the fabric. Mat builds a thick layer and also prevents print-through. Production parts and boats are all built in female molds to avoid having to fair.
Old 08-21-2005, 04:12 PM
Buckle's Avatar
Buckle Buckle is offline
Composite Engineer
Rep: 10 Posts: 83
have u considered using a female mould. without wanting to sound dim, why are you fairing all your moulding. why dont you make a female mould full stop.
if fairing is still required, have your considering investing in polyester fairing compounds/high build, easily rub resins. As there polyester, you can apply as o the laminate is still curing, thus minimizing down time.
Buckle
(Composite Engineer)
Old 08-22-2005, 11:07 AM
Rep: 10 Posts: 14
It's a one off project and it's also on a bit of a shoe string. If I make a female mould then I won't save any work as the female mould will require all the fairing to begin with. It will also require more material.
What I am planning is plywood frames, then bead and cove foam core over these frames, followed ny the outer skin. First fairing will be the foam which should be quite easy. This will produce a fair surface. The second stage fairing is on the outer skin where the shape will be reasonably fair but rough. It's the roughness that i would like to avoid, therefor requiring less work smoothing.
Have I got this arse over elbow?
Cheers
Andrew
carbon glass balsa core rturbett Fiberglass and Composite Boat Building 8 08-31-2005 12:18 PM
1972 Hardtop - Stringer and glass campbell Boatbuilding 2 06-25-2005 12:51 AM
epoxy and glass inside and outside? and more Nordson1960 Wooden Boat Building and Restoration 6 05-22-2005 09:26 PM
Glass over good plywood hull? Ed Hoban Wooden Boat Building and Restoration 10 02-11-2005 01:26 AM
UK - Fibre Glass Workers Required MnM Int. Services & Employment 1 07-07-2004 10:42 AM
